Televison & Video Logo
Mark Batorski Posted on Dec 04, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What controls the backlight on a samsung UN60H6350AF TV
ChinthakaJ
Level 3:
  • Master 943 Answers
  • Posted on Dec 05, 2019
ChinthakaJ
Master
Level 3:
Answers
943
Questions
Helped
301506
Points
2783
The backlight is controlled by the powerboard.
1 Related Answer
lpfaff1
L Pfaff
  • 11573 Answers
  • Posted on Mar 16, 2016
SOURCE: I have a new TV (Samsung UN60H6350AF). !have a NETFLIX account, how can I activate Netflix on this TV?
Earl, contact, How to Contact Netflix
Troubleshooting Network Connection Issues
Complete List of Netflix Originals Whats On Netflix
How To Improve Netflix Streaming On Any Device
1helpful
2answers
Samsung Tv turning on and off, LED light blinks twice
The series set you have has the power and main board as a combo and has had lots if failure issues so I'd try replacing this board, as long as your backlights stay on we can cross those off the list of possible issues
I have a Samsung UN60H6350AF TV. After 1.5-2 hours, the picture washes out. It is still viewable, but very faded. Any suggestions will be appreciated. Thank you.
Check your advanced video settings for something like Environmental LIghting. There's a sensor on your television that reads the light in the room. It can adjust the brightness of your screen to accommodate more or less light. If you turn this off, it will help. You can also request support directly from your television. They will ask you a couple of questions, then setup a time to call you where they are very helpful and will walk you through any problems you are having. If it can't be fixed over the phone by tech support, they will setup an appointment for you to have it repaired. Hope this helps.
Samsung 40EH5300 LED TV backlight flashes continuously when power applied. No picture.
You can find a solution on Youtube also google the problem or consult manufacturers page.
2answers
What is the backlight part number for samsung tv UN55FH6200. Is it BN44-00499A?
If you wish to get some details about LCD LED television ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
I have a Samsung LN40A450C1D TV that has sound but the backlight doesn't come on. I replaced the power supply board and same problem. I then replaced the backlight inverter. Same problem! I'm absolutely...
You have to check all the voltages, that comes from its main power supply board, to its back light inverter board. These is one pin at the backlight inverter board; comes from the main board; which controls the back-light inverter to start and off. This voltage is generated at the main board, and send to the back-light inverter board, as control voltage. It will be best to contact any service technician. If you wish to get some details; check the site linked here.Viewing it in "Mosaic" will make surf easy.
Samsung LCD TV backlight switched off
Most likely you will need to get a diagnoses done on the set. It could be a faulty 24vdc circuit (power supply capacitors), defective inverter, or a failing CCFL backlamp.
2answers
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
