A
Anonymous Posted on Dec 04, 2019
Irc 3380 error code 000602-00105 - Office Equipment & Supplies
Your Consultant
Level 3:
Master:
  • Master 825 Answers
  • Posted on Dec 04, 2019
Your Consultant
Master
Level 3:
Master:
Answers
825
Questions
Helped
206252
Points
1873
I bet if you googled that you would find it instead of asking someone else to do it for you
2 Related Answers
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Jun 26, 2010
SOURCE: error E000003-0002 on copier canon IRC 3380
post-standby fixing low temperature
eason3434
E Eason Eason
  • 12 Answers
  • Posted on Jun 08, 2012
SOURCE: I have a IRC 3380 that I am replacing the fixing unit in. How do I reset the E000003-0001 error code?
press *, press 2 & 8 at the same times then press * , again .it will bring you to service mode ,then press FUNCTION and then press CLEAR then press ERR and press OK ,then reboot the machine .
Testimonial: "Thanks for the quick response!!!!"
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Canon iRC 5185i with the erro code E000007-0201 . i need solution
Belt push-off temporary escape mode error.
Occurs when the belt deviation is not eliminated within 1 minute in the belt push-off temporary escape mode.
2answers
IRC 3380i error code E000001-0003 please help
get into service mode
To get into service mode.....
Press *
Then 2 & 8 together
Then *
then choose COPIER
then choose FUNCTION
then choose CLEAR
then choose ERROR
then press OK
turn power off and on
3helpful
1helpful
2answers
Canon irc 3080i error code e000020-0023
NITIAL FAULT IS ERROR CODE DUE TO WORN BLACK DRUM GIVING PATCHY IMAGE, ON FITTING A NEW DRUM IT CREATES ANOTHER ERROR CODE ABOVE E020, ON RE-FITTING OLD ONE ERROR DISAPPEARS. PATCH CREATED ON ITB IS UNDERTONED DUE TO LESS INTENSITY LASER BEAM PASSING THRO, THE RESIDUE ON THE GLASS, HENCE E020-0023.
THE CLEANING TOOL ON THE DOOR IS INADEQUATE TO CLEAN THIS RESIDUE. PULL OUT PROCESS UNIT TO MAX. LIMIT. PRISE UP THE DUST SHUTTER, THEN CLEAN WITH DAMP WIPE AND DRY IT. REPEAT IF NECESSARY OR TAKE LASER UNIT OUT
Canon IRC 2570 IC Error Code is E000012-0002 problem what is the solution
4helpful
CANNON IRC -2880
this code is for a bad OHP sensor, wich detects transprerencies.
Canon IRC 2880/3380 Scan to Email client
re install the system software , flash the machine, or clear mmi
6helpful
6answers
Scanner Error - Power On > Power Off
Sounds like the scanner has died. Sometimes restarting can help out. If you can print try printing out the configuration page and let us know what the error codes are.
k24674
ADMIN Andrew
ADMIN Andrew
