Garden Logo
Gerald D Healy Posted on Dec 04, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toro snow shovel will not start - Toro Garden
Your Consultant
Level 3:
Master:
  • Master 825 Answers
  • Posted on Dec 04, 2019
Your Consultant
Master
Level 3:
Master:
Answers
825
Questions
Helped
206331
Points
1873
1 Related Answer
David Ellis Rhea
  • 3462 Answers
  • Posted on Jan 25, 2016
SOURCE: Drove into snow. Stuck, rocked,got out shoveled got in and wouldn't start. elect is good. Could snow have damaged wires or starter? I was fine. Til I turned key off in 4wheel. Help.
Yes, Ed, the snow ( or water ) could have done some damage.
The water could have damaged the starter, or the starter solenoid, however, that would really be unusual because they are made pretty waterproof, since they sit near or on the bottom of the engine where there is often a lot of water.
I would suspect the wire from the ignition switch to the starter or the solenoid ( which is a small wire) may have gotten broken or knocked off, or perhaps if there might be a solenoid to the 4 wheel drive might have gotten soaked.
God bless your efforts.
tip
How to build a backyard igloo!
Backyard igloos are easy and fun for kids. You don't need a large amount of snow, either. A few inches can be shoveled into a pile that's large enough for a kid to crawl into, but you need to be careful to make sure that you make it strong enough that it won't collapse easily.
Start out by piling the snow a couple feet high. Three feet is about as small as you can go, but that works well for most kids. It can be as big as you want, though.
After you pile it up, use a watering can to sprinkle the outside with water. It should be cold water, since hot water will melt the snow more than necessary. Make sure you cover the entire outside of the snow pile. The water is the key to making it strong.
Wait overnight for the water to freeze, and then use a shovel to scoop out the snow on the inside. Make a hole in one side with the shovel, and then carefully shave off the snow on the inside until you are close to the edge.
That's it! If the kids want, they can scrape out the snow on the inside with toy shovels, too. Overall time to do a small one this way is just an hour or so, not counting the overnight freeze.
3helpful
Toro snowblower wont start. seems like the fuel isnt getting into carb.how and what can i do
Reference your toro snow blower. does it start and run for a few swconds then die. if so It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now.
Not operating...been stagnant for a couple of years.power snow shovel
Just leaving a comment here too in case you have any more questions about your electric shovel. I will keep an eye on this page too if you want to leave any comments here and I will answer them as soon as I can.
Thanks.
Joe.
Feb 13, 2011 • Toro Garden
Mower won't turn over
Keep it in the kitchen over night. Or anywhere that is environmentally controlled for that matter. Should start right up as soon as you get it outside.
Mower
If it sat for some time without running aslittle as 30 day the fuel is probly stale and needs to be drained and the carb cleaned and possibly a new spark plug
Will not throw snow
I have a toro 421 snowblower won't start after had it fixed from shop and how to operator to starter?
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
