The hot water heater, range, and dryer all have 115v to each side of the 240v circuit. The dryer turns, but no heat...no hot water...nothing works on range.
May only be getting 120v from power pole.
SOURCE: no hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
SOURCE: circuit breaker trips on electric hot water heater circuit
Check the voltage at the water heater. Sounds like the element is burnt out and is tripping the breaker.
If it is more then 5 years old I would check.install a new heating element.
SOURCE: ON-DEMAND WATER HEATER NOT WORKING
I am assuming that this is an electric unit? The heating elements could be bad. I would contact the manufacturer for a service manual for your unit. There you will find instructions on how you might be able to reset the unit if possible. One thing you can try is to shut all power down to the unit and then restart. Also check for any "reset" switches on it as well.
SOURCE: No hot water, Rheem Model RR612T, Electric Hot Water Heater, 60 g
If you don't have current, 0v from terminal to terminal, then you don't have voltage to the elements. Replace the thermostat but check that you have 220v to the thermostat. It is possible that your breakers to the unit are either bad or tripped.
SOURCE: Heating circuit getting hot when hot water is running
Check to see if diverter valve is in domestic mode or heating mode.
