Microwave Ovens Logo
Sam Mardini Posted on Dec 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Baxter rotating oven Model No. OV-851G stopped rotating
I purchased this used oven for my business 3 months ago. It has been working perfectly. Today,the oven stopped rotating. Any idea what problem is? is it the motor? Can I rotate the shelves manually?
barn2897
Level 2:
Habit-Forming:
New Friend:
  • Expert 153 Answers
  • Posted on Dec 03, 2019
barn2897
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
153
Questions
0
Helped
67261
Points
428
Hi Sam-
I found this link.
https://www.hobart.com.mx/pdf/ManualOper/F31199.pdf
On page 20, it talks about "Emergency Tray Operation"-both Electrical Tray Operation and Manual Tray Operation.
Hope this helps.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 13, 2008
SOURCE: OTR microwave turntable won't rotate
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If not, please post your brand and model.
It's probably the motor, but possibly the coupler.
One quick check is to remove the turntable and support / roller ring and try to turn the coupler. It should be a little hard to get started, then you should hear a whirring sound, not a clicking or grinding, which would indicate a bad motor.
If the coupler turns loosely with no resistance, then it's probably bad.
Here is my text on replacing couplers, which had steps which are necessary when replacing motors. Note that if yours is a built-in model, ignore the part about turning it on its side *grin*
NOTES ON REPLACING TURNTABLE COUPLERS
Copyright 2007 by William E. Miller - MicrowaveDisplay.com
UNPLUG THE OVEN FROM THE WALL FIRST OR YOU WILL EXPOSE YOURSELF TO LETHAL VOLTAGES!
Note that I am not encouraging you to work on electrical items if you are not qualified, and I assume no liability for any consequences of your decision to do so.
When replacing the turntable coupler on most models, it is necessary to loosen or remove the screws that mount the turntable motor to the bottom of the chassis.
It is usually easier to do this with the microwave oven on its right (heaviest) side because you will need two hands for alignment.
Be sure to put a towel or similar cushion on the work surface to avoid scratching the oven wrapper (oven cover) or the work surface.
It is not necessary to remove the wrapper or the wires from the turntable motor itself, but you may need to remove a small metal duct covering the turntable motor if your oven has one.
It should only be held on by one or two screws.
Although a broken coupler may come out easily or even fall out, the new coupler will not go in without at least loosening the turntable motor.
Look at the hole in the new coupler. You'll notice it has (most do have) a flat side to it. That flat side will line up with the flat side on the motor shaft.
When the old coupler is out and the motor is loose, you can ease the new coupler in the hole with one hand while turning the coupler very slightly back and forth as you gently push the motor toward it. Do not force the part in.
When the coupler has mated properly with the motor, you should feel it go in.
Be sure it's right, or you may break the new coupler or bend the mounting ears of the motor when you attempt to tighten the screws.
Reassemble in reverse order.
We're happy to help and we appreciate your thoughtful rating of our answer.
Anonymous
  • Posted on Feb 09, 2009
SOURCE: SAMSUNG Microwave Oven Model MD800WC/SC The
my problem you cannot push the digital number what's wrong with my mocrowave, sometimes it comes the time and then as soon as you push the time to heat it stops no power?
Anonymous
  • 6 Answers
  • Posted on Apr 15, 2009
SOURCE: Tuntable keeps rotating when microwave door is open
get a new microwave its nackered
Mukesh Kumar
  • 3230 Answers
  • Posted on Aug 24, 2009
SOURCE: Turntable does not rotate
Well it seems that there is some fault in the turnable motor, turntable system consists of the motor and coupler, turntable support with rollers and the tray.
I have a video link to help you more on this -- how a turntable motor should sound when you rotate it by hand... please follow the below link -
http://www.youtube.com/watch?v=rPSWi_z7M58
If motor grinding... etc., it means you may have a bad motor or plastic coupler.
Post further comments if you need more help....
Good Luck!!
bestdarngood
Benjamin Patri
  • 3037 Answers
  • Posted on Mar 25, 2010
SOURCE: microwave turns on but doesn't heat. Turntable does not rotate
The magnetron (the part that heats the food) is probably done, they tend to go out if the fuse didn't blow and it usually isn't worth fixing as the cost of the magnetron is almost what it would cost to buy a new microwave.
Sorry for the bad news.
Benjamin
2answers
One month ago I bought a rival 0.9 cu ft digital oven,model rgst902 ,I only use it mainly to warm things up, I was in the process of cooking something for five minutes,when I went to get the food out the...
I have the same model, after 2 days of normal operation it has stopped working. No lights on the dislay at all and the keypad is unresponsive. If you open the door the light comes on and the turntable slowly rotates. Im taking it back.
I have an Oster 1.2 cu. ft counter top microwave model OM1201E0VG. I purchased this model about a month ago. Every time we run it there is a grinding noise as the turn table rotates. I have checked...
There is still factory warranty on this and most stores wold even take it back if there is a problem. Please don't try and repair something that can be fixed under warranty or they will void the warranty. My advice is to put it all back to gether and then take it to the store you purchased it from and demand an exchange. They most likely will return it no questions asked if it is that new.
1helpful
My Kenmore 721-63259301 manufactured Sept. 2007 recent stopped working. I first noticed the issue as I went to reheat some leftovers. The unit powered on (internal light lit up turntable rotated timer...
Sorry I can't help you but we purchased this same model 11 months ago and ours just stopped heating this week. Sure expected it to last longer than this.
Model # OGB81201 approx 1 month old. Microwave does not work turntable does not rotate, Convection and grilling apprear to work and turntable rotates when using these features. When i push the quick...
Approximately 1 month old? Should still be under warranty. Before doing anything else, contact the store where you purchased the oven and see if they'll exchange it as defective. If not, they may take the unit in for service there. Failing that, check your owner's manual to see what to do for service.
1helpful
2 months old. bought brand new. and just stopped
These things will happen. You are aware that these appliances have a 12 month warranty so return it to where you purchased it from.
I have a JES1142 which I purchased only one month ago. The turning plate rotates both clockwise and counter clockwise. When it rotates counterclockwise it makes a grinding sound. Why does it rotate bot...
It's normal for the motor to turn both ways, that's because of how the motor is made. As for the grinding noise, there's no reason the motor itself would make more noise turning one direction than in the other. The noise might be coming from the roller ring under the glass turntable. One of its wheels might be binding when it tries to turn counterclockwise.
Here's a test. Take the glass tray and roller ring out of the oven. Put a microwave-safe container with a cup or so of water in the oven and start it. Stop the oven and start it again, and the motor should turn the other way. If not, repeat this until you've seen the plastic coupling turn both directions. Note whether you still hear the noise as the motor turns each way. If you do, then there is something wrong with the motor and it should be replaced. If not, the noise is coming from the roller.
In either case, if the oven is truly only a month old it's still under warranty. Since you are concerned about the noise and are worried that the oven is defective, contact the store where you purchased it and see if they will exchange it or take it in for service. If the store can't help you, refer to the owner's manual for the service procedure to follow.
Hope this helps. Thanks for using Fixya!
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
23helpful
6answers
New Handle for Maxim 3 oven
Hi All -- I just spoke to a very helpful Maxim/Salton customer representative (1-800-231-9786 is the US #), and the glass door for the Maxim OV-300 is considered a "non-stock" part. This means that it's not in stock, but it is (hopefully ;) possible for the company to order it from their manufacturer in China, though it could "take months." I was able to place an order for the door for $20.90 USD including shipping to Los Angeles. Hopefully if others place orders, they'll really re-make some of these parts! Good luck, Penny
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
