Lost my TCL Roku TV remote and need a code to my vizio remote. I tried 11756 for the code to my roku tv and the only thing works is the input button but it will not let me scroll up or down to go to my setting on the tv.
Both remotes cannot be bad. Tv has an issue - have it repaired under warranty.
U might try completely disconnecting the set and then plugging it back in. If still will not work see if there is a reset button. If nada, have repaired.
SOURCE: I can't get my Vizio srs soundbar to work to my tcl Roku tv
Unfortunately your question is pretty weak but if you have all the connections properly set up between Soundbar and the TV you should be able to go in the Roku menu where has a sound set and tell it to use external speakers it's a it's a it's a adjustment there once you do that please by all means also make sure sound and the volume is turned up and even on the TV as well
