Question about Building Materials
Hi, we have liftmaster la400 single gate. It opens or closes only half way. How do I fix it?
    Top Expert:
  • 66,118 Answers
CHECK LIMIT SWITCHES
Posted on Dec 03, 2019
6ya staff
SOURCE:
Paul Blessing
  • 188 Answers
SOURCE: I have a Liftmaster LA400 gate opener. How do I
do you have a voltmeter or multimeter?
Posted on Aug 04, 2009
Don Maggard
  • 3197 Answers
SOURCE: my liftmaster 2265 1/2 hp remote does not close
If the door starts to close and the main light flashes 10 times and the door reverses to the open position it is a problem with the door sensors. Make sure they are pointed at one another and they each have a small light that must be on and not flickering.
If it starts to close but reverses and the main light does not flash 10 times it is possibly the RPM sensor which is a small printed circuit board just in front of the motor.
Posted on Nov 12, 2009
Joe Hogan
  • 10865 Answers
SOURCE: How do I program a new Liftmaster 371LM one button
hello. The programing is the same for both gate openers and garage door openers. Basically you will push the smart button on the gate opener so that it is blinking and then push the button on the remote while it is in close proximity to the gate opener. Here are pix and diagrams for your use. http://www.liftmaster.com/consumerweb/pdfdocs/114A4109.pdf
http://www.liftmaster.com/consumerweb/pages/accessoriesmodeldetail.aspx?modelId=806
Posted on Aug 30, 2010
dltatsjc
Dennis Thatcher
  • 54 Answers
SOURCE: Hi, My electric gate RAMSET
Look for a broken or missing shear pin that connects the drive sprocket to the motor. the pieces should still be in the sprocket and motor shaft if it is a roll pin, which I would expect, and will need to be punched out with an appropriatly sized drift pin punch, It's usually easier to drive out the pieces if the sprocket is removed from the shaft so the holes don't have to be matched up. Replace the pin with one of the same size if available, a soft steel bolt and nut may be used in a pinch but should be replaced with the proper roll pin as soon as possible.
Posted on Nov 13, 2010
Dave
  • 253 Answers
SOURCE: gate light on even when gate is closed
Open gate and find where the wiring enters the gate (bottom of door) pull back the rubber insulator and check for broken wires or wires touching each other.
Posted on Mar 05, 2013
Have a BFT Phobos BT gate opener. The problem I am having is my gate won't close all the way. There is a small gap. I tried to set the limit switch by removing the screw but it isn't...
The opener may have been mounted improperly or may have slipped from it's original mounting location. You may not be able to make an adjustment because the arm is already fully extended.
You may have to re-position the gate opener.
Fixya doesn't do repairs. Posting a question here is like calling the public library for an answer that they can look up.
Feb 02, 2015 | BFT R93524500001 - Swing Gate Kit, Single,...
Linear SWR-211 gate opened and got stuck when it tried to close. Tried reset and shut power off. Still stuck in half open position.
So the gate is stuck in a half open position? If you have already tried resetting it, you might just need to call in someone from the company. Some gates have an emergency retract option. You can look for that, at least it wouldn't be just half open.
Elisa Jed ' http://www.anviliron.net
Jul 09, 2014 | GTO Automatic / Electric Gate Lock Fm-143
La400 gives force reversal code, can clear code and it comes back over and over without the arm trying to run. nothing happens.
You have a bad main board. I have encountered this recently while repairing an la400. I am a gate operator installation tech.
Sep 27, 2013 | liftmaster LA400 Circuit Board Main Logic...
My gate is equipped with a D3 Centurion gate motor. When I push the button to open the gate, the motor turns in the opposite direction (close) and tends to close further. Then if I deactivate the gear box...
if you push the open button and it closes indicates that you have the wrong polarity connected to the motor
gate motors are DC so where the positive and negative wires are connected are critical for rotation direction of the motor
Jul 29, 2017 | Garden
DSealed Lead Acid Batteries: 12v 7ah; belongs in a Liftmaster LA400 gate control box. Can these batteries be charged using a trickle charger? I'm trying to find out if it's the battery not holding a charge...
Yes you can charge the 12 volt bttery on a trickle charger. You should use a 1 amp or less charger. Check the battery every 1/2 hour or so for heat. If it get's hot you should stop charging. Power packs that have a 12 volt rating will charge your battery safer and better but will take longer (like a cell phone charger) look at the voltage ratings on the charger. You will have to adapt the plug to hook it up and test for correct pos. and negative connections. The 7amp hour batery should be fully charged by a .5 amp (500ma) charger in about 14 hours (multiply the amps times hours of charge and do not go over the 7amp hours of the battery when deciding how long to charge). After charging check voltage, it should be around 12. Let the battery set for a few hours (overnight) and check the voltage again. It should be around 12 still. A fresh charge will usually show a higher reading (called a surface charge) than a battery sitting around. 4.5 v will not operate your device, 9.5 v or higher should.
Aug 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
A 12 volt battery needs about 13.5 volts to reach a full charge. It should stay at what ever voltage you bring it up to, with no load connected.
Most gate controls are solar charged and should be fine under normal circumstances.
Charge the battery with a regular 'automotive' type charger and then test it with a few cycles, open and closing gate.
Also check voltage from charger at gate...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 05, 2009 | Electronics - Others
Building Materials Logo
Top Building Materials Experts
Tom Chichester
Lawrence Oravetz
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
