FOUL TASTE OR SMELL IN ICE OR WATER FROM FRIDGE
Check ice and water filter: If equipped, the Ice and Water filter in your refrigerator is responsible for removing any debris or contaminants from your water that may still remain after local water treatment. Most filters contain and are made up of carbon and fabric filter. Over time, the filter may become restricted and reduce the water flow to the ice maker, causing a symptom of little or no ice. Most manufacturers recommend replacing the filter every 6 months but local water conditions may require that you replace more frequently. Lastly a clogged drain line can cause a foul smell and get into the ice and water as we,,.
http://www.appliancerepair.net/refrigerator-repair-1.html
SOURCE: Refrigerator Smell
Is the problem more in the freezer than the fridge section. If it is it is possible that on a defrost cycle the heaters which warm the coil may have warped and ar heating something they shouldnt. Another possibility is if there is something in the condensate tray (where the water collects) or something touching the compressor which runs very hot, or even the compressor relay if it is a 'plastic' smell. Smells are notoriously bad things to trace as engineers normally turn up when the smell is either gone or so faint as to not to detect. All I can suggest is trying to narrow the search area as much as you can and hopefully youll find it. Hope this is of some help.
SOURCE: odor in fridge
Probably getting a new Fridge-mother doesn't want to continue to deal with repairs. Thanks anyway.
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
SOURCE: refrigerator smells strange
I may have found the problem. I pulled out the Fridge again. The odor was in the water pan.
What I found was that the cooling grills in the front was caked with dust. I vacumed this area but it was not until I got down with a flash light and saw this issue. I took a small duster that uses static to pull the dust out. There was a lot. I will see if the smell starts up again.
SOURCE: Bad smell coming from fridge
Unplug fridge. Remove the panel on the back of the fridge look for dead rodents or fungal growth in the drain pan. consult your local appliance parts distributor for a product called kleene air or try www.reliableparts.com
