Just go to official shop
https://pokerab.com/
SOURCE: Lg invertor air con "neo plasma"
i have the same, only way to get goin is turn off at mains. ive now tried running on fan low .... got this tip from another problem and seems to work.
good luck
SOURCE: need to find manual to download for LG 2.5 hp neo
You can find it her, you just need to have the full model number, probably located in the control panel http://www.lge.com/us/support/product/support-product.jsp
SOURCE: LG neo plasma air conditioner
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
SOURCE: have a 4horsepower neo plasma split that keeps
Please note your fuse wire must be 2 to 3 times of running amps. Suppose running amps is 6.5, the fuse wire must be minimum 15 and maximum 20 amps. Always choose the maximum.
Other chances for fuse blown;
And in your a/c, If your fuse tripped as soon as compressor starts, check compressor winding with ohms. In between 2 terminal it should be equal in 3 phase compressor. In single phase compressor, SR must be the total of other two.If any huge difference it means winding weak. If any ohms reads between any terminal and grounding it means compressor grounded for which you have to replace compressor.
Hope, it's helpful?
SOURCE: Air conditioner is turning on
Hello Naeva
Plesae visit the link provided below :
http://www.mylg.co.uk/data%20for%20site/Multi%20F_dx_%20Fault%20Codes%20-%20Nov%2007.pdf
http://www.abacusairconditioning.co.uk/lg%20split%20codes.pdf
http://www.ehow.com/info_7983149_lg-air-conditioner-error-codes.html
