Question about Rowenta Irons
How to replace the fuse on Rowenta Dg5030? - Rowenta Irons
    Top Expert:
  • 2,147 Answers
I think there's no fuse in this steam iron. If the iron does not work, the thermostat or the power cord may be damaged.
Posted on Dec 02, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Need a cap gasket for a Rowenta DG5030
I showed the part to my husband. He took it to our local Aubuchon Hardware and bought the same size gasket for 59 cents. I just tested it out and my iron works just fine now. The one from the hardware store is black, vs the Rowenta one which is green. Who cares what the color is, no one sees it anyway. However, if you have to send your machine for repair for something else, they may not honor your warranty as you've now added after-market parts. Just thought I mention that. Good luck.
Posted on Jan 23, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Rowenta Steam Iron DG5030; Iron drips water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
knoxjd
SOURCE: my rowenta dg5030 is leaking at the cap
My question is what is Rowenta doing about the gasket problem. Where is the replacement.
Posted on Nov 08, 2010
kebah
Angel Joseph Jr.
  • 684 Answers
SOURCE: do you know where I
Hi there.
You can buy parts for your steam iron at http://www.rowentausa.com
Regards.
Posted on Jul 15, 2011
valiantma595
Michael C
  • 176 Answers
SOURCE: The electrical connection 0n Rowenta steam iron DG5030 is inconsistent. I wish to disassemble and check the tightness of connection
Screws may hold the shell together but the halves are usually clipped together by hooks around the edge of the shell to discourage would be 'electricians' from doing home repairs. Once you've removed the screws and the body held by the screws doesn't come apart, look for a point where you can insert a screw driver in it to pry the body part out. If you can't do that, then don't do it. best thing to do is take it to a repair agent. At least it's safer.
Posted on Dec 28, 2014
My rowenta dg5030 will heat but the water will not heat
The Boiler unit is not working have it repaired, or get a new one!
Jul 26, 2014 | Rowenta DG5030 Iron
Steam comes out the filler cap on the water base on my Rowenta DG5030
WIre brush the caps screw threads and replace the O Ring ASAP.
DOn't use the iron until you get a new O ring and they need to be the orange/red rubber ones they are able to withstand the hot steam black o rings at home depot won't last.
Jul 24, 2014 | Rowenta Pressure Iron and Steamer DG5030
Fix rowenta dg5030
Send it in for repair.
Google Rowenta Repair Center
Jul 22, 2014 | Rowenta DG5030 Iron
Rowenta iron dg3050 iron potion broken and will not hold steam can you replace the iron part
More than likely your steam valve is broken or stuck. I had one of these and they are worth having repaired. Google Rowenta Repair Center.
Jun 15, 2014 | Rowenta DG5030 Iron
Steam comes out of the place where you put the water in
check the holes in the hot plate are not blocked with lime scale...sounds like you have a back pressure problem
Dec 29, 2012 | Rowenta DG5030 Iron
My rowenta dg5030 is leaking at the cap
Oct 14, 2010 | Rowenta DG5030 Iron
Jan 10, 2009 | Rowenta DG5030 Iron
Irons Logo
52 people viewed this question
Top Rowenta Irons Experts
Ekse
Kate Henkel
Level 1 Expert
Gil Shultz
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
