SOURCE: TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Simple solution.
Press the C.Lock key on the remote.
This key tunrs on and off the child lock feature.
cheers.
SOURCE: Power Will not function
It is most likely a 1000mF@25v capacitor in the power supply. Replacing this cap usually fixes the set.
SOURCE: ps3 wont turn on using controller and power button...
try cycling the power on the back of the console
are the lights blinking on your controller when you press them?
