Question about Russell Hobbs Kitchen Appliances - Others
Russell Hobbs electric kettle 3122, maybe 8 years old, has been playing up recently, only starting when given a twist and turn on its base. Now the fuse blows every time when switched on . Any ideas?
    Top Expert:
  • Russell Hobbs Master
  • 66,248 Answers
TWISTING AND TURNING HAS SHORTED OUT THE WIRING SUGGEST YOU INVEST IN A NEW ONE ,IF YOU STILL NEED THAT TYPE OF HOT POT PERSONALLY I HAVE A WATER COOLER THAT ALSO HEATS WATER FOR TEA ETC AND IT IS ALWAYS READY AT THE TOUCH OF THE BUTTON
Posted on Dec 01, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Russell Hobbs kettle element model 10413
The only way to get hard to find Russell Hobbs electric kettle parts is from Russsell Hobbs. They will not sell any parts that are in short supply or becoming obsolete. Please visit their website, follow the instructions for repair and send the unit to them.
Posted on Mar 03, 2009
Anonymous
  • 44 Answers
SOURCE: kettle will not heat. Russell Hobbs corded
Check mains fuse, if ok check for voltage at kettle , with multi meter, not phase tester as these can be faulty, if you have power and no heat then it has to be the switch or the element, check and replace same. if your unsure have an electrician do it for you
Posted on May 01, 2009
Anonymous
  • 120 Answers
SOURCE: russell hobbs electric coffee percolator cord require a new cord
Go to a parts store and pick up a new cord.
Posted on Oct 08, 2009
cahazuka
  • 161 Answers
SOURCE: Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Posted on Jan 12, 2010
specialistel
  • 8909 Answers
SOURCE: Every time i plug in
I suspect the element has failed and going down to earth. New kettle time I think.
Posted on Mar 10, 2011
Tip
Leaks
I have had two Russell Hobbs electric jugs in the last several years. Both eventually leaked at the spout seams. Not good enough !!! In my opinion something is wrong with the workmanship or design.
on Nov 28, 2007 | Russell Hobbs RHJK3063 Cordless Electric...
How to enter code
instructions - Russell Hobbs
uk.russellhobbs.com/pdf/14590_stylis_black_kettle.pdf
2 Don't put the kettle, stand, cable, or plug in liquid. ... 4 Don't open the lid while the water is heating. 5 Don't ... 8 Put the kettle on the stand - take care not to spill. .... To avoid environmental and health problems due to hazardous substances in electricaland electronic goods, appliances marked with this symbol mustn't be.Missing: code
Kettles - Russell Hobbs
en.russellhobbs.com > Our Products
Over the decades, Russell Hobbs has been at the forefront of quenching our national thirst for hot beverages with fast, easy to use, great looking electric kettles.Missing: open ‎question ‎enter ‎code
Russell Hobbs KE9000S Electric Kettle, Stainless Steel
www.amazon.com/Russell-Hobbs...Electric.../B00A15...
Amazon.com, Inc.Amazon.com: Russell Hobbs KE9000S Electric Kettle, Stainless Steel: Electric ...
Jan 13, 2016 | Russell Hobbs Kitchen Appliances - Others
My old Russell Hobbs K3 switches off before it has boiled. Is there an adjustment for this, if so, where? Thanks, Ann
The thermostat is non adjustable and must be replaced. Unless under warranty still, it's cheaper to replace the kettle.
Sep 10, 2010 | Russell Hobbs Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
wadingriver
wadingriver
bobalix
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
