SOURCE: copier will not print documents
turn off copier on the left side lower left to the rear there is a cover with one screw holding it in. remove screw and cover behind it is the waste toner bottle.. Empty bottle then at the top of the bottle is is 2 little circle indents (windows) clean those indents inside and out put bottle back in turn on copier that should do it good luck
SOURCE: ROM Error for Canon Image Runner 2010F
When the ROM Error message is displayed on the control panel, this
will indicate an issue with the Flash DIMM on the Image Processor PCB.
re-flash the system software for
that specific model. If system software does not resolve the error,
replace the DIMM Assembly. When replacing the DIMM, you may be required
to flash the system software to it's latest version.
iR 2010F FG6-9454-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the
STOP key. This may boot the iR to a ready state and copies can be made.
SOURCE: waste toner
to change the waste toner on your IR 5055, stand directly in front of machine and look on the right hand side of it where the power switch is a black button on right hand sdie at the back and you will see 4 screws and a metal plate that will come off the waste toner bottle is in there just empty it out and refit to machine all will work, now on your IRC3170 just undo front door and you will see a clear bottle just undo the black screw and take out the bottle and you will see a couple of little clear windows in the bottle make sure you take them out and clean them before you emtpy the bottle, this is where the machines shines a light through it to tell if the bottle is full or not so make sure you have them clean. refit the bottle and all will be ok
SOURCE: code de panne E000584-0003 for canon image runner
Please check the main thermistor TH1 has poor contact or open circuit.,the thermal switch is opened.In this case the fixing heater has opened and the SSR is faulty.
For the reset : COPIER-FUNCTION-CLEAR-ERR.
