Question about Hobart Kitchen Appliances - Others
Could someone tell me why after turning off my Hobart 4046 meat grinder it started leaking oil from the bottom of the grinder?
  • 14,825 Answers
Bad oil seal.
Posted on Nov 29, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Black Residue on meat using Kitchenaid meat grinder attachment
the guy that said that the meat produces this is full of it since the black reside is the blade friction against the round metal piece with the holes, i had black fine powder all over my mixer without any meat
Posted on Jul 19, 2009
Anonymous
SOURCE: I have a Kitchenetics K-11 mixer with a meat
You can buy parts for your machine here:
http://www.mykitchencenter.com/Details.cfm?ProdID=1359
You may have to call them and inquire as to the specific part you need - they also have used parts that they sell.
HTH!
Posted on Aug 21, 2009
Cuisinexpert
Cuisinexpert
  • 61 Answers
SOURCE: oil leaking from hobart d300 mixer
DEFINITELY contact the manufacturer (Hobart) on that one. Sounds like you're having some sort of an internal problem with it (something might be cracked), and in this situation, the best way to go is to contact the manufacturer rather than try to repair it yourself. If you're still under warranty, and you try to open the machine up to fix it yourself, you could wind up VOIDING the warranty, and if you're out of warranty, most repair places won't touch a machine that you've messed with already--too much of a liability.
Just give Hobart a call, and they should be able to help you (if you're in warranty, sometimes even for free!). Their phone number (according to their website, www.hobartcorp.com ) is 1-888-4HOBART (1-888-446-2278)
Good luck! :)
Posted on Aug 27, 2009
traboH
traboH Mr
  • 27 Answers
SOURCE: I am looking for a place to download a manual of a
Parts and Owner/Instruction manuals are available at:
http://www.hobartservice.com/
Hobart considers Service manuals to be proprietary info and they are generally available only to "authorized" servicers.
All the best.
Posted on Oct 09, 2009
vestxre
  • 119 Answers
SOURCE: Need to fill gear case with oil for Hobart meat
35 ounces.
Posted on Sep 13, 2011
I am looking for a wiring diagram for Hobart 4822 grinder
Ask direct. not available online.
Electrical Installation; Electrical Connection - Hobart 4822 Installation ...
https://www.manualslib.com > ... > 4822 > Installation and operation manual
  1. Cached
Hobart 4822 Manual Online: Electrical Installation, Electrical Connection. The Electrical Installation Of The Chopper Must Conform To The Local Electricity...
[PDF]4822 MEAT CHOPPER 4822 MEA T CHOPPER - Hobart
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F7515.pdf
  1. Cached
  2. Similar
Page 1 of 2. 4822. MEAT CHOPPER. 701 S Ridge Avenue, Troy, OH 45374. 1-888-4HOBART ... CORD AND PLUG: A 6 foot, flexible 3 wire cord is furnished with the ... CAPACITY: 4822 will grind 16 lbs. per minute, first cutting through a 1?8" ...
[PDF]CATALOG OF REPLACEMENT PARTS
www.hobart.co.kr/data_file/4822Aug04.pdf
  1. Similar
4822 CHOPPER REPLACEMENT PARTS. F-43093 (August 2004). © HOBART. Table of Contents. 3. ELECTRICAL UNIT. 5. #22 CHOPPER ATTACHMENT ... wiring diagram for Hobart 4822 grinder Google Search
Feb 08, 2017 | Hobart Food Mixers
I have a hobart 4642 mixer grinder that s leaking oil Need help with diagnosing
can you confirm the model number and where the oil is leaking from?
Hobart make a 4246 and a 4632, but I am not familiar with a 4642
Feb 11, 2014 | Food Mixers
How to pull auger drive shaft for Hobart 4346 mixer-grinder?
The oil seal is the resistance you feel. take a soft mallet or hammer with a soft drift and gently but firmly tap the stub shaft and it will drive out the oil seal in the hopper direction.The lower skirt of the tapered bearing is what contacts the seal so go slow.
Worked for me.
Jan 23, 2013 | Hobart 4346 Meat Grinder Mixer Chopper...
Need to adjust clutch on hobart 4346 meat grinder how do you do it?
On the 4346 mixer/grinder the clutch can't be adjusted. It is a Moorse clutch and will need to be replaced. If you ate handy buy the rebuild kit for the bottom end from Hobart. It's not cheap but once it's done it will last for years. Hope this helps, Food luck
Dec 16, 2012 | Hobart 4346 Meat Grinder Mixer Chopper...
What kind if oil goes in a hobart meat grinder
Mineral oil or a food grade oil should be used. I would check with a restaurant equipment supplier in your area.
Feb 23, 2011 | Vacuums
I am looking for a place to download a manual of a Hobart 4812 meat grinder.
All the best.
Oct 04, 2009 | Hobart Food Mixers
This is a common issue with the Kitchenaid food grinder. The black residue is a product of the meat itself.
With Kitchenaid Food Grinder Attachments, it is recommended that the meat be partially frozen before grinding. This is to ensure a quality grind and to make sure the meat holds all its juices while grinding.
If any juices from the meat are leaked into the food grinder, the friction will cause a chemical reaction and turn the juice from the meat into a black substance.
Dec 17, 2008 | KitchenAid K45SS Classic Stand Mixer
Kitchen Appliances - Others Logo
26 people viewed this question
Top Hobart Kitchen Appliances - Others Experts
Treefrog15
Treefrog15
Colin Stickland
Colin Stickland
Dennis Boxerman
Are you a Hobart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
