SOURCE: Epson workforce 600 continue to
If this message appears when you turn the printer on it will need a repair, this will be down to a sensor fault.
If this message appears when you try to print Check you are using the correct paper type and size settings, on the printer if being used standalone or via the printer driver if using via a computer.
Also try using a different paper type and brand ideally Epson paper as it is an Epson printer. If the fault continues the printer will need a service.
As this printer was released this year you should be covered by some form of warranty, contact Epson for a service.
SOURCE: My cannon pixma ip 1600 keeps giving an error
Hello there
You may not see a paper jam, so this is worth trying.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: 202 printer jammed error message appears, but could not locate
Here's an article in the Lexmark website on Error: "201 Paper Jam" or "202 Paper Jam". This will guide you on where to locate the cause of the problem. Follow the instructions. But if you're having a really hard time locating it or you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
SOURCE: HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
SOURCE: my brother mfc-6490cw printer keeps
my brother MFC-6490CW keeps coming up with an error message 'cannot print 70' how do i solve this?
