Question about The Watches
What is the battery lifeof a brand new Galaxy watch .mine has run all the way down in less than a day
    Top Expert:
  • The Master
  • 30,336 Answers
3 to 4 days. Take it back under warranty
Battery Life: Going the distance
Samsung claims that the LTE versions of its watches will go the distance; the 270-mAh battery in the 42mm model will last up to three days, while the 472-mAh battery in the 46mm model will last up to four.May 20, 2019
Samsung Galaxy Watch Review: Get It for the Battery Life ...
https://www.tomsguide.com > samsung-galaxy-watch,review-5705
Posted on Nov 28, 2019
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: I just bought my wife a michele csx-36 watch. Its brand
that happened to me too...the watch repair man told me that I had the stop watch on. The stop watch should serve as a stop watch, not the second hand. The second time on your watch is the small dial at the bottom middle of the face. Once I turned off the stop watch feature, my battery life is fine...I have not had to change my battery in over 2 years now. HOpe this helps.
Posted on Feb 28, 2010
ankitchandel
Ankit Chandel
  • 141 Answers
SOURCE: Watch runs then stops. New battery. Pulling stem
tie your watch for some time to provide some heat anothervice you must be check it's lnternal parts........
Posted on Mar 27, 2011
David Tolond
  • 2501 Answers
SOURCE: Brand new Invicta Pro Diver
If you have any problems with a new watch you should go first to the supplier and if they can't help, contact the maker.
Most makers have a service depot who can help you.
You can find your nearest service depot by going to the Invicta web site (http://www.invictawatch.com/) and clicking on "service " in the menu bar at the top and there is a link to instruction manuals.
The battery should be OK unless the watch has been part of a window display for a considerable time. (Most of the batteries I have used lasted 1-3 years).
Posted on May 04, 2011
How do i set the day ? Mine is stuck on sun.
I would try removing the battery for 10 minutes reinstall the battery if it doesn't help there's a problem with the circuitry.
Hope it helps thank you.
Jun 10, 2015 | Novelty 30M Waterproof Analog & Digital...
I just purchased a women's mk 5057 chronograph watch 2 days ago. I believe I set the time properly and according to the manual however it continuously slows down. Each hour it managed to become 7...
Quite possibly but FIXYA has no idea what you might have done . If you bought it thru a local business , go there and have them assist you . even brand new things can fail , possibly the battery has been in it for too long since manufactured .
Sep 15, 2017 | Michael Kors MK5057 Wrist Watch for Men
Brand new Invicta Pro Diver Watch 0923. The watch will work fine for a few days and then just stop working. I will reset the time and it will work for another couple days and again stop working again. I...
May 04, 2011 | Watches
New watch bulova 96R-19 women, and dont know how to start...
I have read the instruction for this watch and I am surprised how little they tell you!
The description of the watch does not say if it is automatic or battery driven so I shall give you two alternatives to try:-
1) If it is battery driven, then there may be a wedge under the winder to prevent it going into the running position (to save the battery while it is on the shelf). Pull this out and push the winder home.
2) If it is automatic, then it is mechanically driven by a spring and needs to be wound up. This is done by either turning the winding knob or gently shaking it from side to side form some minutes. Once going, such a watch needs to be worn daily to keep it running. They will normally run for 1 - 2 days before stopping when not being worn.
If you were not given instructions with your watch, you can get them from their web site http://www.bulova.com/brands/bulova/product.aspx?origin=sku&sku=96R19&brand=bulova.
Dec 22, 2010 | Bulova 96R19 Wrist Watch
I just bought my wife a michele csx-36 watch. Its brand new. The watch runs for about one day then stops . What do you think it is. We did replace the battery already. Thanks
Dec 14, 2009 | Michele CSX Diamond watch
After replacing a battery in a timex ironman with data link, they tell you to short the ac pad and the vss pad. Were are those points located?
You will find them on the module itself.
So after replacing the battery look on the PCB (printed circuit board) for the letters"AC" and "VSS". Adjacent to these markings there should be little contact points (probably gold or silver looking in colour)
Use a paper clip or similar and bridge (short) these two points simultaneously. Please rate my solution.
Jul 26, 2009 | Timex IRONMAN Triathlon Data Link T53722...
New watch is losing 5 to 15 minutes a day
This could be that the battery is slow. Newer swiss watches have a indicator in the movement of the watch that makes the sweep second hand skip every few seconds to indicate that the battery is slow. On regular japan made watches the watch just simply starts slowing down. Your watch could be new but the battery in it could have a long shelf life.
May 11, 2009 | Kenneth Cole KC1104 Wrist Watch
Pulsar NX14 Digital Display gone blank
Do not panic yet - all you need is the battery replacement.
Don't mind that the watch is less than a year old - it may laid in sellers store for a year or so and as the watches are not refitted with the brand new battery at the selling point, they may have underpwered battery much more quicker than you expected
Find your nearest watch repair shop and ask for battery replacement. Your watch will tick as brand new and will last much longer then before.
Do not forget to rate, please.
Jan 12, 2009 | Watches
Watches Logo
21 people viewed this question
Top The Watches Experts
 Larry
Larry
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Watch Expert? Answer questions, earn points and help others
