Question about Tag Heuer Watches
TAG HEUER 2083 stopwatch cannot switch off the display when finished
I have a TAG HEUER 2083 stopwatch. It has laid dormant for many years but I had just replaced the battery and it works fine, but I cannot switch of the display when finishaed
    Top Expert:
  • Tag Heuer Master
  • 66,228 Answers
THEN IT DOESN'T WORK FINE
Posted on Dec 03, 2019
6ya staff
SOURCE:
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
Anonymous
  • 3 Answers
SOURCE: Tag Heuer Formula 1 Mens watch
battery number 395!
Posted on Jan 02, 2009
Anonymous
SOURCE: Tag Heuer CA 1211-RO Min. Hand resets to 59 Min.
Unscrew the crown and pull out halfway. Use the stopwatch buttons to advance the hand to where you want it. Then push the crown back in and screw it down. You may need to pull the crown out all the way--I cannot recall which setting controls the minute hand and which the hour hand on the stopwatch function. This has to be done every time the battery is changed.
Posted on Feb 05, 2009
Bob Gemmell
Bobby G
  • 212 Answers
SOURCE: Tag Heuer watch runs fine; can't set time or date.
Are you aware that the crown is threaded and it needs to be unscrewed and pulled out once to adjust time and twice to adjust date
Posted on Aug 07, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Tag Heuer Carrera CV2A10 date display changes at 3AM??
Unfortunately, there is not much you can do with this, as for fixing it you need very experienced watch repairers help. All I can do is just name all possible reasons why it happened. FIRST reason could be: the day wheel somehow has lifted and not sitting in correct position. This would be the easiest fault for watchmaker to repair, as only dismantling the movement, correcting the day wheel and re-assembling will be necessary, so, no serious repairs needed. SECOND reason can be: the star, which is friction fitted to the day wheel is getting loose. In this case, if watchmaker will not be able to fix the day wheel, you will have to buy new day wheel + all work previously explained. THIRD reason: the day wheel click spring is weak/bent/broke. In this case you have to buy new day wheel click spring + again all the work previously explained. FOURTH and last reason: day wheel positioning screws/borders became loose. In this case only the work explained in FIRST reason will be necessary. If you are so lucky and still have warranty for your watch - send it back to Tag Heuer and they will do repairs without charge, because this fault is covered by warranty. If warranty has expired, you do not need to find any particular Tag Heuer watch repair shop. As all watch movements are manufactured on identical basic principles, any reputable/decent watchmaker will do the job for you. Prepare yourself to pay quite a lot, because Tags are expensive to deal with and takes a lot of time and skill to fix. This is all help I can give. Wish you luck. Rate me, please, and/or write some testimonial if you have spare minute.
Posted on Mar 25, 2010
Testimonial: "Thank U so much for the enlightenment, escapement. Your points really do ease me alot. Will go to retailer/svc shops and we'll see from there. Cheers!"
How do I turn off eol on my tag
"EOL" means "End of Life." The battery needs to be replaced soon. I agree with other post. . . if you had the battery replaced recently, it was bad. I have had my Tag Kirium Formula One for 12 years and have only replaced the battery once.
May 10, 2014 | Tag Heuer Kirium Formula 1 Chronograph...
Tag heuer stopwatch
Pull out the middle dialer once then try if that's doesn't work pull it again one will be the chronograph the other will be the stopwatch and if you turn the middle dialer it will change your clock
Apr 27, 2013 | Watches
My tag heuer carrera stop watch doesnt reset properly, when u reset the stopwatch it goes one minute behind and doesnt reset to zero. how do i fix this. it never resets to zero and the red hands on the sub...
Try this.
Pull the winder out fully. Then press the top right chronograph button to move the centre seconds hand on. Then push the winder back in.
on some models you should only pull the winder half way out.
good luck
Sep 23, 2010 | Tag Heuer Carrera Tachymetre CV2013.FC6206...
STOP WATCH NOT WORKING
mcdevito75 here, Best Bet, return to the shop that changed the Battery, it may not be the absolute correct battery, Battery could have come slightly loose.
Jul 21, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
Can tag heuer link bracelet be repaired? seperating in the middle
It depends.
First if the Tag watch is older then it cannot be repaired by Tag and Tag won't have any parts for it.
If it is new, Tag should have the parts and a watchmaker or Tag themselves could repair your band. Although I would suggest a watchmaker over Tag if you can find one willing to deal with Tag for the parts. Expect this to take months to get the right link parts.
If it is older then we have repaired some of these with laser welding. Although there is no guarantee as to how long the welds will last, it does seem to work out for a while.
The ones we have done have lasted several years. In fact we just had a customer send his watch back in for a battery and we had welded his Tag clasp back together about 3+ years ago and it is still working just fine.
Hope this helps,
Ken
Yellowstone Watch Inc.
Oct 05, 2009 | Tag Heuer cj1110.ba0576 Wristwatch
Jan 23, 2009 | Tag Heuer Link Automatic Chronometer...
Reset Button on Tag Heuer watch has fallen off
That's right, nothing will hold that button in place as clipspring has fallen off or broke and retains inside the watch. Do not wind or wear your watch now as that clipspring is freely floating inside movement and can damage your watch geartrain.
Find your nearest watch repair shop and ask to refit button with clipspring. Watchmaker will know how to do the job and how to get rid of any broken remains if there are any.
Don't forget to rate, please.
Jan 11, 2009 | Tag Heuer cj1110.ba0576 Wristwatch
Tag Heuer Link, stopwatch seconds hand stops 2 seconds before 12
Pull crown out to position 2 [in between unscrewed (1) and pulled all the way out (3)].  Tap Button B (bottom) to reset by step back to zero.
Incidentally, Button A works Hours register in same manner for position 2.  You can similarly reset second and 1/10th with Buttons A and B, respectively, while in position 3.  Cheers!
Jul 25, 2008 | Tag Heuer Link Automatic Chronometer...
Is My Battery Dying?
Do not think so. But try another battery and see what the result is - you might get lucky. If it continues to do the same you will have to accept the obvious - something is bogus with the unit.
May 03, 2017 | Tag Heuer Kirium (CL1212.BA0705)...
Watches Logo
32 people viewed this question
Top Tag Heuer Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
