Hi Mike-
I found this youtube video regarding a dishwasher door that was stuck shut and would not open.
https://www.youtube.com/watch?v=4qM3Sud7sPw
I also found another youtube video regarding opening a dishwasher door that will not open.
https://www.youtube.com/watch?v=VE2FY_U7_qY
Hope these help.
Video at the link below suggests it may have a locking feature:
https://m.youtube.com/watch?v=XAauYps8k5E
SOURCE: Whirlpool Gold GU15 dishwasher won't start
The appliance repair technician just diagnosed the problem for me. He says it's a bad touchpad, and it would cost $257 for him to replace it. Thought I'd share the diagnosis in case anyone else comes upon this thread.
SOURCE: causes of a blown thermal use and a whirlpool gold dishwasher
Your lint vents in the dryer are clogged.
Your connecting vent on the rear is clogged.
Your through the wall vent is clogged.
Could be any one of these problems or a combination of these.
In any event, you have poor air flow.
SOURCE: Our Whirlpool Gold dishwasher does not drain. What
Hello there:
If the water doesn't drain from your dishwasher,
check these:
Drain line/air gap
A clog in the drain line or air gap (if there is
one) is the usual reason that a dishwasher won't drain. Often the
problem is at the point where the drain line attaches to the garbage
disposer or household drain line. If you remove this line, you can clear
any debris from the hose or hose connection. Be sure to reattach the
hose before starting the dishwasher again.
Pump
Your dishwasher pump ejects the water. The pump is
usually mounted directly to the motor, then attached to the bottom of
the dishwasher. You can reach the pump from inside the dishwasher, but
first you need to remove the lower rack, the spray arm, and the spray
arm support.
Look for an impeller--a round plastic fan
blade-type of device that spins around. This is the wash impeller, which
forces the water through the spray arm. Beneath the wash impeller is
the drain impeller, which is similar in size and shape to the wash
impeller. The drain impeller pushes the water toward the drain port. If any of the pump components are
defective, you need to replace them.
Drain valve and/or solenoid
Many dishwashers use a drain valve with an
electric solenoid. When electricity flows to the solenoid, the valve
opens and diverts the water to the drain. Sometimes the solenoid, or the
diverting lever, sticks and prevents the dishwasher from draining or
filling properly. Try to free up the solenoid to lubricate the lever.
Otherwise, you may have to replace the solenoid or pump assembly. With
these systems, the motor always rotates in one direction. When it's
energized, the drain valve diverts the water.
Other dishwashers reverse the direction of
the motor to drain the dishwasher. These units don't have a drain valve.
Instead, there's a drain hose connected directly to the pump housing.
MotorIf the motor isn't turning or working, the unit
won't drain. First check to be sure you have power to the dishwasher. If
not, see the section "It doesn't work at all." If the motor hums but
doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck
if you don't run them regularly. If you haven't run the dishwasher for
more than a week, you may need to manually spin the motor to free it up.
If the motor is defective, you need to replace it. Dishwasher motors
can't be serviced.
Timer
Part of what the timer does is control the motor
and drain valve. If the timer doesn't work properly, the water may not
drain and you need to replace the timer.
SOURCE: I have a Whirlpool Gold Series dishwasher
You have check where the leak orginates from.If it is from the frame you to check the gaskets. If the machine is old chances of the gasket becoming hard is possible.
Try cleaning the body of the machine Gasket pressing area.
SOURCE: I have a GU1200XTKQ0 Whirlpool Gold Dishwasher. I
If you have a Wet/Dry Vacuum, then you can use that to **** up any debris you see in the bottom of the Dishwasher. Make sure you remove the paper filter from the vacuum so it does not get damaged from the water in the bottom of the Dishwasher. I use the vacuum trick to clean up the muck from the pump area and it works well.
Hello &
Welcome to FixYa
Press and
hold the AIR DRY/RINSE ONLY button to reset the control, if you have already
tried this and it is possible that the door was opened while in cycle then the
first thing that should be checked is the door switch/lock assembly. You can
take a hair dryer and try to blow air on that, if the problem returns then
replacing the door switch/lock assembly is recommended repair. Please get back
to me if you have any other questions.
Kevin
