The backplate is a "pry open" back. so you will need something like a blade or a hard thin flat object to pry the backplate. once this is done you will have access to the battery. Please note that there is a tiny Philips screw that holds the battery plate. you will have to remove this screw and then remove the battery plate. Also, note that around the case there will be a thin rubber "o" ring. this is what makes the watch water-resistant. so pls male sure you fix it back when you reinstall the watch.
SOURCE: I have Minicci watch and
It is real. Manufacture in China is cheap and many of brand names are manufactured there.
Japanese movt is right and real as well as these are mass produced for many different brand names.
SOURCE: no watch setting directions
Some of the inexpensive watches like to mimic the expensive watches and put fake dials on the face of the watch. That way you get a Breitling look alike at the price of a Timex. If there don't appear to be controls for the dials, chances are that they aren't real dials, Look closely.
SOURCE: How can I get back off a Disney watch with Japan Movt?
i use a razor and a hammer.or send to me watchrepairbattery.com
