SOURCE: How do I install a
The procedure is as follows:---No adhesive required. The gasket goes inbetween the inner and outer door panels. Thanks. Keep updated for any more query. You can rate this
solution and show your appreciation.
Before replacing the gasket, soak the new gasket in warm water for an hour or two, then dry it with a towel.
Open the door, remove door bins, then starting from the top replace the door gasket in sections. Mentally divide the door in quarters. Remove the old gasket from the upper 1/4 and install the new gasket in place. Then the 2nd 1/4, etc. This will help keep the door panels even.
Keep in mind that you have to give it about 24 hours for the new gasket to take shape. After 24 hours, do the dollar test to make sure it's sealing correctly.
Dollar test: very simple. Slide the dollar bill inbetween the door and the cabinet, close the door and pull on the dollar. If you feel resistance, it's fine. Do this about every 6 inches all around the door. If you come to a spot where you don't feel any pull on the dollar bill, try adjusting the gasket.
The other procedure to do the same freezer door gasket replacement is as follows:---
Heat the new gasket in the bathtub to get it smooth and shaped right, then remove door, put it on a flat table, loosen all the screws, and remove gasket. Put the new one on, tighten screws and mount door. Use a hair dryer to smooth it out. Sometimes necessary to duck tape the door shut overnight to get it to seat properly. Also helps to have the fridg leaning back a bit, helps pull in the gasket.
