Question about Exercise & Fitness
Is a bionix treadmill good for running and being inside?
  • 14,826 Answers
Yes....
Posted on Nov 23, 2019
6ya staff
SOURCE:
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
NordicTrack x9i Terrible banging sound coming from belt roller in back
Try to lubricate the treadmill running belt.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Treadmill walking belt lubrication
Jan 02, 2017 | Nordic Track Exercise & Fitness
Does the 3500R nordic track need batteries?
Depending on the model. Some have batteries, other have power provided by the Treadmills transformer inside the console. If you can locate the battery holder/box behind the console, then the console works is not connected to the electricity supplied by a small transformer in the console. Add the batteries. If there is no battery compartment then it runs on electricity. Remember that treadmills are delicate equipment that run for years with proper care. Always lubricate the running belt with a good quality silicone spray. To avoid making a mess on the floor or carpet, spray the silicone on a lint-free cloth to give a light soak outside the home and then go back inside and lift the running belt high enough to be able to wet the base with the cloth. Run the belt a minute, then swipe the cloth a second time. Next check with your fingers or hand if the base feels wet and smooth, suggesting that the base is now lubricated, before using it. Do not apply too much as the belt can spray traces of liquid similar to a car tire spraying water on a wet road. Hope it helps.
Jul 31, 2014 | Exercise & Fitness
When on treadmill there is a "studder"
Check if the running belt is lubricated. You can't run an engine without oil. So, spray a good quality silicone lubricant on the base of the running belt. It is best if you spray on a lint free cloth just enough to make a wet patch. Do it outside so that no spray residue lands on the floor and becomes slippery or lands on the carpet and stains it, then return inside and lift the treadmill running belt and soak or smear the base with the wet patch of the cloth and run for a full minute. Then lift the belt again and give it another swipe on the entire base, then feel the base with your fingers or hand to see if it feels wet and smooth. Run the treadmill for another minute at slow speed, otherwise the liquid can fly and splatter on wall or floor. If it still hasn't solved the problem, then it must be the motor brushes, or it may be set to run slow and fast according to the running settings on the console. Mine does the same thing if it is programmed to do 1 minute slow and one minute a bit faster. Good luck.
Jul 30, 2014 | Proform Crosswalk 395 Treadmill
NordicTrack Treadmill A2050, Will not work or turn on.
1) test the outlet wall , put a desklamp and see if work, if work the problem will be in the machine,
2) test the fuse inside for blown and replace with the same capacity
3) reset the circuit breaker inside.
4) test the power cord for open or defective.
Try again, if the machine NOT work, the problem will be in the power supply see the block atached.
God bless you
Sep 19, 2012 | Nordic Track NordicTrack Elite zi...
Adjust voltage on motor control board
Dear Sir:
You can adjut the voltage motor in m.m.board.
The only way is 1) Put some regulator voltage in the line for to maintain the voltage in the line Good 2)Try to get some circuit special for your treadmill without interference 3) You can add the voltage from the transformer inside from your machine.
However You can RUN the software calibration for diagnose, troubleshooting, and fix it.
sincerely. God bless you
May 07, 2012 | Reebok treadmill i-run s
Running belt has creased badly, will I need new belt ?
Wow, this is weird, I've just come back from the gym and the guys there were 'fixing' a crease on one side of the belt.
They had the belt off the treadmill, and put a wooden board on the inside, with some weight plates on them, a few wooden blocks on the inside, so the belt looked like it was the same height as when it is fitted and then a wooden board and weights on the top.
By the time I'd finished my session, they were refitting it and it looked good, you could still see a slight dent, but not a full crease.
Hope this helps you and good luck.
Jul 18, 2010 | Tunturi T30 Programmable Treadmill
Is a Preor m9.2 considered a good treadmill? It costs $500.
If it runs smoothly & the display works, yes it's a good deal.
Jan 20, 2010 | Precor 9.21 Treadmill
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
