This camera takes a lithium battery and if it is left to fully discharge then you may never be able to charge it up again. Your answer may be another battery. Find a cheap third party battery to try it out.
If you're getting the 18-4489-957-000 error code, then give it a good tap on the corner where the lens cap is. A little tapping and the lens cover should pop closed. When you turn the camera on again it will probably work just fine.
I was just about to junk my camera when I googled the error code and found this very tip in another thread. It worked like a charm.
I've had this happen a few times. I simply removed the memory card and reinserted it. Usually that does the trick on the first try. On a bad day I've had to do it 3 or 4 times in a row until it just worked.
