Error e 00014
SOURCE: fuser unit breakdown error sc380
Hi there you will need to replace the development motor but first try the following.
Entering the Service Mode
There are two ways to enter the service mode.
Method 1: Turn the machine on while pressing the “On Line” key and “Escape” key
together until the above message in the illustration appears on the display.
NOTE: If you switch the machine off, any jobs stored on the hard disk using the
sample print and protected print features will be deleted.
Check first with the user tools to see if there are any jobs stored with these
features
(Menu key - Sample Print, or Protected Print).
Method 2: Press the “Up/Down arrow” keys together for about 5 seconds, then
press the “Enter” key.
The above message shown in the illustration appears on the display.
NOTE: The machine automatically goes off line when you enter the service mode.
Using the up down arrows select Engine and enter by pressing enter or # key.
Using
the up down arrows select mode 5 then enter using enter or # key then
select 810 (SC reset) press enter then if you want to select 809 (SC
Detection ON/OFF) Enter and select 1 to disable. Escape or return key
all the way out and exit. Turn the machine off then on again and test
if the same problem then replace the Dev unit if still having the
problem then replacement of the motor likely. I can email you the
complete service manual if you like.
Thanks J
SOURCE: Canon IR3170CI got a error E0014-002
k these are notorius for having bad upper rollers if they sit for a long time if you turn the green knob on the fuser and feel hesitation or its hard to move then easy.. or if it sounds like a washing machine at warm up you need a new fuser even if youswapped it the one you put in if not new may be bad
SOURCE: Canon D880 Error -- E000
From a fellow FixYa expert, "Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in. If this don't work, get a new fuser."
SOURCE: canon irC6800 error code is 00014-001
its a fixing unit related error check the shape of the spacer on the rear side of the fixing roller
SOURCE: There is a error code
This failure usually occurs by the fuser unit is locked. usually because the ro-liner pressure roller lock up, cleaning the caul of the fuser roll it up .. fuser unit generally does not rotate properly and adequately lafurza stumbles ... finally verify the dc motor control.
