SOURCE: Cannot find the model number
If this was a scratch and dent model, model number may have been removed prior to sale. If not, you should find it on the back edge of the washer at the very top as you look over the back of the machine. If you can't find a model number, bring the part(s) you need to a servicer. They may be common parts or there may be some identifying numbers on the parts themselves. Good luck.
SOURCE: ge washing machine top load model wlsr3000 will
grab agitator and **** up. Remove metric bolt and coupling. Tighten large nut to the left
SOURCE: I own a GE Commercial Quality 3 Wash Spin
Hi, if your washer pumps out the water but doesn't spin, check these:
SOURCE: washing machine does not stop
The water fill valve (the plastic thing that the hot and cold hoses go to) has an obstruction (piece of rust or minerals from the plumbing) and the valve won't fully close. A speck in the right place is enough to cause overfilling.
or
The water level switch is defective.
or
The tubing that is attached to the level switch is loose or off. This hose must be tight on the fittings.
