Do you have a question? Is this a door on a kitchen cabinet?
What type of hinge?
I will assume you have eurostyle hinges like almost every cabinet in the last 20 years:
https://www.youtube.com/watch?v=vtKnxyvxuEs
https://www.diynetwork.com/how-to/skills-and-know-how/carpentry-and-woodworking/how-to-install-and-level-cabinet-doors
https://www.wikihow.com/Hang-Cabinet-Doors
Seriously easy to find on Google...
SOURCE: Door constrained by adjacent cabinent
You need the "Some Other Solution". Do Not mess with the MW Door Hinges! They have been set by the factory to safety requirement to prevent MW Radiation Leakage. Altering Door Hinge could place you and your Family in harm.
SOURCE: hardware for Pottery barn Cameron cabinet doors
I would remove one of the hinges and take it to a good hardware store. They will be able to order replacements for you. good luck.
SOURCE: I am making new kitchen cabinet doors.
If you are using European hinges then then you will need a 25mm forstner bit for your drill. Using a drill press with an adjustable depth stop is recomended.
Testimonial: "thank you very much for your help *******"
Removal of Cabinet
(Do not use decorative panel to move the machine)
1. Isolate power supply.
2. Remove service and decorative panels (refer Section 6.1).
3. Ease machine forward for all round access. Be careful not to damage floor coverings.
4. Remove two screws from bottom sides of cabinet rear.
5. Remove the top screws on left and right hand sides of the cabinet rear.
6. Remove two screws securing the rear bottom panel.
7. Remove five screws securing the stainless steel frame to cabinet wrapper at front of machine. These are located behind the sound gasket and service panel.
8. Withdraw the cabinet assembly away from the machine.
Refitting: Refit in reverse manner. Fitting the top centre screw in the cabinet wrapper first, makes fitting the cabinet easier.
6.9 Removal of Door Tension Springs
Location: The door tension springs are located either side of the machine and are
fitted to the chassis base and door quadrants by means of the end hooks of
these springs.
After isolating the machine from the power supply:
1. Ease machine forward for all round access.
2. Remove service panel (Refer Section 6.1).
3. Remove two screws in the cabinet wrapper exposed by the Service Panel.
4. Remove the springs from the quadrants and the chassis base using pliers.
6.10 Removal of Hinge Assemblies
(Do not use decorative panel to move machine)
Location: The hinge assemblies are located either side of the door and retained by means of two rivets on each side to the inner door panel.
1. Remove service & decorative panels (refer Section 6.1).
2. Remove outer door panel (refer Section 6.2).
3. Remove cabinet (refer Section 6.7).
4. Remove door tension springs (refer Section 6.8).
5. Remove quadrant grommets.
6. Open door fully and drill out the two rivets from the hinge assembly on inner door panel.
7. Hinge assembly can now be removed from inner door and cabinet.
Note: Hinges should be replaced one at a time. Repeat procedure six and seven for other hinge. Hinge guide quadrants can now be removed by depressing sides and pulling free of slot if need be.
Refitting: Refit in reverse manner using 3/16 monal rivets to secure the hinges to the inner door.
