SOURCE: Machine stuck mid cycle
filter blocked or brawire or similiar in drain pump take off cover at bottom rear. take of hose going to bottom of tub. filter is in that hose you will have water everywhere. one way round that is to lay machine on side - left side down viewed from rear
SOURCE: Hoover washer Time 1600 H160E UK stops mid cycle with flashing lights
REPLACE TIMER OR POWER CONTROL BOARD
SOURCE: Door lock light flashing
More likely the PCB needs replacing - common fault, you could try a new door switch first cost £5 new PCB £65+ but is easy to replace.
SOURCE: Hotpoint Aquarius WD440 Error
Remove the white plastic cover on the back near the bottom. To the right as you look at it their will be a black concertina pipe with a hose clip on its top edge. Undo this and pull the pipe downwards to reveal the filter. There will be a plastic ball inside (which is supposed to be there) remove this and clear out the cr*p.
Re-assemble as removal.
That should fix it
SOURCE: The door locked light keeps flashing on my
Sounds like needs new door interlock swith Cost around 15 pounds.....Simple to fit
