Televison & Video Logo
T
Tricia Crawford Posted on Nov 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i scan for channels on my hitachi RC A48105. I do not have a manual
Vernon Taylor
Level 3:
  • Hitachi Master 7,446 Answers
  • Posted on Sep 27, 2020
 Vernon Taylor
Hitachi Master
Level 3:
Answers
7446
Questions
0
Helped
1959789
Points
26207
I don't know but it probably isn't much different to most other tv/remote combinations where commands are given by the remote and carried out by the brain in the tv.
Start by pressing the Menu button and the main menu should appear onscreen and from there use the up, down, left and right buttons to navigate the main menu and the select button to select sub-menus and items from the menu(s) until you reach the section on channel search, installation, etc.
1 Related Answer
Anonymous
  • 668 Answers
  • Posted on Jun 17, 2009
SOURCE: cant attain digital channel scan on hitachi rear projection tv
Do you have the tuner locked out for use of HDMI input only?
Most of the time when a selection is not able to be hi-lited it is
because a feature that is activated locks out other selections.
Hope this helps,
Skyassoc
I'm trying to connect to antenna. Every time I scan the channels it only scans Channel 1.
The main system control memory IC to this set is faulty. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
2helpful
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
1helpful
2answers
I have a Hitachi C2856Tan-301 TV with no user manual. How do I search for tv-channels?
are you sure it is a 2856? I've narrowed your manual down to this page http://www.retrevo.com/samples/Hitachi-TV-manuals.html#a
If you're trying to get channels from the air, switch the input to air/tv (varries depending on brand) Then in the general settings, should be an option for 'run auto scan'
wish i could be of more assistance
I have no instruction manual for hitachi 32ld30ub
[PDF] 32LD30UB 32LD30UA - Hitachi European Service Sitewww.hitachiserviceeu.com/scripts/userguide.php/32LD30UB_EN.pdfFile Format: PDF/Adobe Acrobat - View as HTML
32LD30UB. GB. Instructions for use .... Electronic Programme Guide (EPG) .................... 20 .... Manual Channel Scan ............................29. Clear Service List (*) .THIS LINK ABOUT IS ALL YOUL NEED TO GET A FULL 58 PAGE INSTRUCTION MANUAL FOR YOUR SET, IV JUST AN HOUR AGO PRINTED THE SAME DOCUMENT MYSELF, HOPE YOU CAN GET YOUR PROBLEM SORTED NOW. X
Cant attain digital channel scan on hitachi rear projection tv
Hope this helps,
Skyassoc
1helpful
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
