Washing Machines Logo
Alex Shcheglovitov Posted on Nov 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have LG WASHER why the water coming out from the filter
robert
Level 3:
  • LG Master 2,548 Answers
  • Posted on Nov 24, 2019
robert
LG Master
Level 3:
Answers
2548
Questions
0
Helped
870458
Points
8043
Not tight? Bad o-ring? Cracked housing?
1 Related Answer
Anonymous
  • 15935 Answers
  • Posted on Sep 18, 2010
SOURCE: LG front load washer OE error. cleaned filter need
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
Problem with LG WM1814CW Front Load Washer. It has stopped with water inside and it says OE. I have checked the back pipe, but with water inside, can i open filter
The OE error is telling you the water hasn't drained out in ten minutes. To fix I would first start with cleaning the filter on the pump. If that doesn't fix i would recommend replacing the pump. I would also have towels and a mop in hand because when you unscrew the filter top the water that is inside the tub will come out. You should try leaning washer back before removing filter to prevent the mess.If you have to replace the pump they run about 50 or 60 bucks. I hope this helps.
I have the LG wm2487h*ma front load washer.My washer is filling up with water when not in use. When I wash a load, the water does not go in the washer. Have opened the door thinking the wash cycle is done...
The problem would appear to be the water inlet solenoid valve.
The valve is not operating correctly for some reason allowing water into the machine even when switched off
2helpful
2answers
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Water is slow to come into machine, we have hard water. A Filter?
You might have sediment from your hard water built up in the water valve to the clothes washer. You might have to replace the water valve. These clothes washers do not have a filter in the for the water. Hope that helped,
XCEL Energy Repairman
Slow flow of water in washer
CHECK WHERE THE WATER LINES HOOK UP TO THE WASHER NORMALLY THERE IS A SCREEN INSIDE THE WATER INLET PORTS
Washer/Dryer
weak pump...but remember in the drying cycle water is ment to come in and flush out lint and produce air flow for drying..it also cools drum..
LG WM2016CW front load washer
Check to make sure that the filters in the water valves are not clogged up.  Go behind the machine, turn off the water supply and disconnect the hoses on the machine side.  Look inside the water valves and check the filter screens to make sure they're clean.  Get a large bucket and open the water valve to clear out the hoses and make sure you have good water flow coming out of the hoses.  If both of those situations are cleared up, your machine should work properly.
LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
