Question about Sharp Refrigerators
How to remove right freezer door so I can replace plastic stopper on the base of the freezer door Sharp model number SJ-F624ST-SL
6ya staff
SOURCE:
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: GE Spacemaker 1800 Handle Base Replacement
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Dec 06, 2007
Anonymous
SOURCE: model 795.77309600
call a service tech from Sears, this is a fire hazard,light control is bad,apparently, modification includes thermal switch,to turn off lights in the event of failure.
Posted on Nov 08, 2008
merlin_35
  • 12 Answers
SOURCE: IFrost Free Sharp Refridgerator & Freezer-Fridge not keeping cold
You have a defrost problem. You need either the defrost timer, defrost heater, or the defrost bi-metal. If you have a meter you can ohm out the heater and the bi-metal ( as lonh a s the bi -metal is frozen as it opens when it gets warm to cut out the defrost heater) if you have an ohm reading on either one of the two the replace the defrost timer, if you don't then replace the part that has no ohm reading.
Posted on Sep 14, 2009
terry gardiner
  • 34 Answers
SOURCE: My freezer door will not stay shut. Dometic Model RM2453.
yes you can.remove two screws from under one side pull it away slightly and it will come away.you will then have one housing on both sides left in the fridge wall,they will have a little pressure on them from the springs. just prise them away. you will need help to replace them, as you need pressure against the spring to keep the door closed. you can buy springs and housings seperately from camec there is left and right housings.give me a call if you need to ..
Posted on Jan 03, 2010
Stoney Thompson
  • 433 Answers
SOURCE: removing plastic door panel on a 2003 gmc sierra
what are you wanting to know?? the door is panel is still held on with clips, if your wandering why it still wont come off... start from the bottom corner of the door and work your way around. you will know when all of the clips are pulled lose, then just lift the panel up off of the door.
Posted on Dec 04, 2010
Sharp SJ F60PC SL refrigerator-freezer is freezing the refrigerator compartment.
I would take a look to make sure your coils are not frozen or covered with ice on the inside of the fridge on the back wall and also double check the drain line on the back.
You could have a faulty switch that controls the thermostat as well.
Jan 17, 2018 | Sharp Refrigerators
Hye..recently i just notice my sharp plasmacluster model sj-pt491m-bk the chiller is not working. Not cold as normal. The above freezer working normally. Plz advise
Open Freezer Door Press Door Switch and checked Freezer Fan is working or not.
If fan is working then problem in Ref compartment. If not working then replaced Fan.
In Ref Compartment checked all duct clod air is coming or not.
If not coming then Damper is defective.
Dec 25, 2015 | Sharp Refrigerators
My sharp freezer model SJ-229S-SL , UPPER IS WELL BUT BOTTOM NO COLD
Checked Damper in Ref its working or not. You can checked open Ref door press Door Switch and hold your hand near chiller tray Duct
Dec 27, 2013 | Sharp Refrigerators
My sharp SJ-F70PV-SL is not cooling properly
Switch off your ref for 8hrs till all Ice melt in freezer compartment. Switch on Ref and checked Air coming from Ref duct or not.
Apr 02, 2013 | Sharp Refrigerators
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
How do change the ref bulb on sharp ref model sj p43n - sl
Unplug the refrigerator. Remove the lamp cover by lifting up at the bottom of the cover. Then unscrew the old bulb and replace with an identical appliance bulb (Base E12, 240V, MAX 15W, T-20). This bulb is at the top center of the fridge.
The manual is available here: http://safemanuals.com/414159.php?ID=1286636&k=3942fa3f433aa4c53ff8bcb7d07ae8e8&q=SHARP%20SJ-P43N/P47N/43N/47N . You will need to review the fridge or enter a code to download the PDF. The light replacement instructions are on page 6.
I hope this helps.
Feb 25, 2011 | Refrigerators
Refrigerators Logo
41 people viewed this question
Top Sharp Refrigerators Experts
geob91
Elie Balas
Vernon Taylor
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
