Question about Plumbing
Faucets-kitchen-dripping - Plumbing
    Habit-Forming:
    New Friend:
  • 89 Answers
Need more information make of faucets so forth
Posted on Nov 14, 2019
6ya staff
SOURCE:
Donni Steen
  • 687 Answers
SOURCE: dripping faucet
Moen is a cartridge style unit. They make two different cartridges that you can buy at Home Depot. Turn the water off under the sink and then remove the handle. You will see the the cartridge. It has a U shaped retaining clip that pulls out. Once you remove it, then take a pair of pliers and pull the cartridge out. Take it up to HD and match the one you have. The new one will slide right back in and you will reverse the process.
Posted on Mar 16, 2009
Anonymous
  • 21 Answers
SOURCE: My Moen Caldwell 87888 continues to run and drip
This sounds like there might be some dust in the cartridge have you pulled the cartridge and looked for dust.
Posted on Jun 21, 2009
motor1258
Mike Butler
  • 6674 Answers
SOURCE: We have a Moen 87315C kitchen faucet and it is
If it's leaking at sprayer, and not the base where connected to hose, try this. Buy a bottle or jug of CLR. (calcium, lime, rust ) from hardware store, and pour enough in a bowl that will submerse sprayer in it. When you go to bed, or out for a few hours, turn off both taps (obviously) and relieve all pressure as well from sprayer. Now wrap an elastic around the handle of the sprayer so that lever is depressed, and submerse it in the bowl of CLR, and let it work overnight or at least for a few hours. Next Day, or Later, remove elastic from sprayer, and try it a few times and see if leak has stopped. Quite often you get calcium build up on internal washer/seal, and this will clean it off. If no CLR, you can try vinegar as well, but I find CLR better. If it appears better but not stopped completely, give it another treatment.
Posted on Apr 13, 2010
John M
  • 67 Answers
Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
Posted on Jul 26, 2010
packrat1948
Paul Beyer
  • 528 Answers
SOURCE: water is dripping out the
Just in case you need to do so.
  1. Turn the water off. The water control knob is located under your sink and is connected to the drain. Turn it counterclockwise to turn off the water.
  2. 2
    Open the faucet to relieve any differences in pressure. Pull up on the faucet as you would if you were turning it on.
  3. 3
    Plug the drain of the sink with its stopper to prevent any parts from going down it.
  4. 4
    Turn the faucet handle sharply to one side to reveal a small cover plate. Pry the plate off carefully with a flat-bladed screwdriver.
  5. 5
    Unscrew the screw that is located behind the cover plate with a 4 mm allen key.
  6. 6
    Lift the handle off and remove the cap beneath it.
  7. 7
    Firmly grip the exposed cartridge with your hands and pull up to remove it.
Read more: How to Remove the Cartridge from a Danze D403412 ' eHow.com http://www.ehow.com/how_7640485_remove-cartridge-danze-d403412.html#ixzz1D76xWEgn I your case I think all you need are new o-ring seals on the spout. once you have the handle off and have gotten to the cartage grab the spout and turn back and forth while pulling up and remove the spout you will see the o-rings. I would get the repair kit before you start. The video below is not your brand faucet but the o-ring replacement is about the same. http://www.youtube.com/watch?v=AipEYoYiIhc
Posted on Feb 05, 2011
Fix a dripping single handel moen faucet
you can go on line with the make
Nov 11, 2013 | Moen Plumbing
Leaky kitchen faucet
What kind of faucet? (single handle, double hndle, kitchen, bathroom) Where is it dripping from? (handle, aerator or faucet head, under the sink) There are many types of faucets and many types of leaks. Sorry to be so vague but there's a pretty wide spectrum of possibilities, a little more info will go long way.
Feb 04, 2013 | Plumbing
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
Dripping faucet price pfister kitchen
Jul 25, 2010 | Price Pfister Savannah Two-Handle Kitchen...
My Faucet started dripping. I have installed two
Be sure you have the right kit for your faucet. I think there are two types of springs. I usually leave the ball adjustment loose, and tighten the cap. Then I use that little spanner wrench to tighten the ball. Have you used the little wrench to tighten?
Jun 30, 2010 | Delta Model 470: Signature Kitchen...
I have delta palo model kitchen faucet that has a
Delta faucets have a lifetime warranty. Call them and tell them, they will send you a rebuild kit. You can rebuild the whole faucet, it will work like new again.
May 02, 2010 | Delta 467-SD Palo Single Handle Kitchen...
I had a dripping Kohler Finial kitchen faucet
Any bit of dirt or grit in the line will get caught in the cartridge if not flushed properly.
Apr 18, 2010 | Kohler K-16109-4-CP Revival Kitchen Sink...
Montuori2947@att.net
check hose to head connection ,i.e. spout.
Apr 14, 2010 | American Standard Kitchen Faucet 6310 020...
Plumbing Logo
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
