Computers & Internet Logo
Aine Yoas Posted on Nov 13, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a SONY VPL-EX4 DATA PROJECTOR that shows FREQUENCY IS OUT OF RANGE. I have been using it on Windows 10 and on different computers desktops and laptops.
I have changed operating system to Windows 7, still the same issue. I have changed the resolution to 800 x 600 and 1080 x 768 at frequency of 60Hz as recommended by one of the online sites https://answers.microsoft.com/en-us/windows/forum/windows_8-hardware/frequency-out-of-range-when-connecting-laptop-to/457f7bb5-d929-4383-8b1a-d3c3524b7d7a still, NO SOLUTION. i have open it and cleaned the dust, may be to check if the problem could be within, still, NO SOLUTION. I have changed different VGA cables but NO SOLUTION found. I would appreciate if anyone can get me any other solution to try out. This projector is driving me nuts. thank you.
goneforever.
Level 3:
Top Expert:
  • Sony Master 14,531 Answers
  • Posted on Nov 28, 2019
goneforever.
Sony Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263647
Points
66315
This is easy, that OUT OF range means
the PC sending video is sending and illegall higher resolution
than the projector supports (or even less, on this old junk)
the manual on that old projector is clear on that. max.
SONY VPL-EX4 2007, 13 years old now.
and back then projectors STINK !
your manual shows this, and stinks.
what stinks worse is no matrix of legal H./V resolutions shown in the manual. (shows only 1)
so set the PC to 1400 x 1050 and do not use others . ok.
and 60Hz, are you in USA? not stated country.
I have a SONY VPL-EX4 DATA PROJECTOR that shows FR - sony-undefined-undefined-0.jpg
  • goneforever. Nov 28, 2019
    some PC can not to SXGA+ size. 4:3 oldhttps://en.wikipedia.org/wiki/Graphics_d...
    and is not wide screen format that most PC only support. there are cures, that are expensive
    one is blackbox adapter, that does varial scan and pan conversions, all projector forums cover this, not here but real ones, this is nothing new in the funky world of old projectors.
    they were grossly limited then to chips that did the conversion then, POOR is the word
    sorry.
    the projector that old is DDUMBB(sic)
    out of range never lies. it is wrong RESO
    out of the PC, I presume VGA right?
    There is one more IMPERIAL entanglement.
    many old Projectors fail to have working
    VESA, reporting chip,eDID or DDC, etc.
    and the PC can not know what it supports lacking modern, ID chips in that old projector.
    this makes plug play fail, and then you get to fight that. (can be forced sure)
    also no PCs stated. by you.
    MANY PCs, (most) do not do them all.
    Desktops can, my wonderous, z270prime with GTX1650 card, does 1400x1050, 60hz no problem
    but many cards can not,
    4.3 RATIO is obsolete now, but as I said good PC can.
    the projector may only support 4:3
    and not any above 1400:1050.
    modern Projectors can up scan and down scan but the chip inside is like 100x better than yours.
    that is it in a nut shell.
5 Related Answers
A
Anonymous
  • Posted on May 07, 2008
SOURCE: Sony VPL CS5 Multimedia Projector Problem
The Temp/fan light is on and is shutting down the projector what do I do
A
Anonymous
  • Posted on May 10, 2008
SOURCE: Acer data projector
dell inspirion 2200 cannot connect to acer projector vice versa help
Anonymous
  • 2028 Answers
  • Posted on Jul 26, 2008
SOURCE: connecting PC to TV
Most tv's are not compatible in this matter. They were made to be a tv, and not a computer monitor. Some of the newer tv's are compatible. If they have a vga port then they are compatible, but may not support or have the resolution expected. The vga to s-video cables were designed mainly for the use of the newer computers with vga ports to older flat panel monitors with s-video ports, at the time that vga was first coming out. This cable is on the verge of obsolete. So, I don't believe that you're going to be able to hook the two together, and get the outcome you want.
Fwayne
Rick Davis
  • 97 Answers
  • Posted on Dec 23, 2008
SOURCE: Connecting Dell Inspiron 1501 to TV, Windows Vista
The PC card you have doesnt appear to work with that adaptor. Dell Has its own Svideo / Video output adaptors.
You need a converter not an adaptor. Try looking on Amazon for this: ITV-900 PC to TV Converter
SALMAN NASEER
  • 1011 Answers
  • Posted on Apr 20, 2009
SOURCE: Sony Ericsson W580i USB Driver for Windows 7
Try this.....
Sony Ericsson - Update Service - Update service software
Follow the instructions to install the USB Flash driver. ... W580i. W200i. K550i. W800i. K508i. K790i. K530i. W960i. P910i. K700i. W550i. Z520i. M600i. W660i ...
sonyericsson.com/cws/support/updateser...
hope it will fix the issue so dont forget to rate it...
"Frequency out of range" when plugged into macbook
Hi Douglas.
Try going into your display settings and change your screen refresh rate/display. If your screen refresh rate is too high/too low this will cause your issue. Also check your screen resolution. Hope this helps.
2answers
Please send me circuit diagram of vpl ex4...
I have a copy of the service manual which contains service information - electrical adjustments - troubleshooting - spare parts - block diagram - frame schematic diagram. If you want the copy, let me know your email add and I will send it to you for free.
Jdvillanueva
Hi, I work in a Sixth Form College in Leicester and we have a Sony VPL-EX4 Projector. The picture seems all washed out, any advice how to correct this please. Thanks
You can make all sorts of adjustments. From your description, it sounds like the contrast and brightness are mis-adjusted.
If you do not have the manual, you can download it from here.
Best of luck, Jim
I need drivers for sony vpl-ex4
Data projectors don't need any drivers.
1helpful
Data projector is not turning on. How can I check for broke fuses?
open up the top case. the fuse will be on the power supply board right next to where the power cord plugs in. you'll need a continuity tester to test it. if it is blown, replace it with the exact size and type. if it is not blown, replace the power supply.
1helpful
2answers
Frequency out of range on one VPL-EX5, but no
change the resolution to 800x600 and if it works raise the resolution step by step
15helpful
3answers
Vpl-es4 sony projector-frequency out of range
Pl. send me solution. I am stuck with problem
vpl-es4 sony projector-frequency out of range.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
