SOURCE: My Nokia 3250 is in offline.
reinsert sim of ur fone and it will ask there continue in offline mode?select NO there and choose another profile....
SOURCE: Nokia e65 stuck in offline mode.
step 1>switch off your phone and turn it on again
step2>you should get a respond <: continue in offline mode>: select no
finally, i believe that everything should be ok.
if it doesn't there is alternative 2???/////
ALTERNATIVE TWO: this is useful for those who got INSERT SIM CARD RESPONSE.
WHY INSERT SIM CARD PROBLEM ?
my phone is 1yr and 6 months now and i discovered that as you remove and replace your Sim card numerous times, there is a big possibility that Sim card port will get expanded.
SOLUTION is very simple:.>>:1. buy a black solo tape
2. place it at the outer part of the sim card and use blade to cut exactly the same shape as the sim card.
3. finally stick the tape.
WARNING>>?do not stick the tape on where you have the Sim card service sensors.make use of your brain.
SOURCE: nokia 6120 shows offline how do i get it online
I just did it with a little help from the first response. However, exact steps are: Go to SETTINGS then go to PROFILES. My cel options are NORMAL, SILENT etc. Go to NORMAL then....gees, since I have it on line again, I can't remember if you go to ACTIVATE or CUSTOMIZE. One of those two options will tell you, "YOU ARE OFFLINE, WOULD YOU LIKE TO GO ONLINE" Of course you will choose ONLINE and VOILA!
SOURCE: want to remove my nokia
HI,
Please follow the below given navigation path
menu-->settings-->phone settings-->offline mode
select off to remove it from offline mode.
If you have any queries Please let me know
Thank you,
SOURCE: how to remove offline mode
Please restart your phone. After restarting, it will ask do you want to continue in offline mode, select NO. This should solve your problem. Make sure you have SIM card inserted in your phone.
