The watch switched to military time on its own.
Https://www.google.com suggests several web sites with suggestions.
http://tv.manualsonline.com/support/armitron/watch/i-cannot-get-my-watch-off-military-time-5752670
Quoting: "David posted an answer 3 years ago
Press the MODE button (B) three times to enter the time setting mode. Press the RESET button (A) to tab through seconds, minutes, hour. The ST/STP button (C) scrolls through the number choices. When selecting the hour, if you want 12hr time format make sure the AM or PM is displayed next to the number you deszire. There are 48 possible selections for the hour - 12 for AM, 12 for PM, and 24 for military time. Keep cycling through until the correct hour comes around. Once you have the correct choice, press the MODE button once more to exit time setting mode."
SOURCE: Armitron WR165 watch - changing time
When you're in the regular time mode press "set". The secons should blink. Pressing "mode" brings you to the hour spot (hour should blink). Press "adj" to change the hour. To set the min., press "mode" again and the min. spot should blink press "adj" to change. Keep pressing "mode" then "adj" until all necessary time components are set correctly. Press "set" to get to regular time mode.
SOURCE: armitron black all sports watch WR 165
Download a manual from their web site to tell you how you how to set it. See download web site below.
http://www.armitron.com/watch_instructions.asp
SOURCE: How to set an Armitron WR330 Watch
he following labels are on the inner ring of the watch; I've given
their positions relative to where numbers would be on the face of an
analog watch.
"ST/STP" is at 2:00; "EL" is at 4:00; "MODE" is at 8:00; and "ADJ" is at 10:00.
To set the time, date, and day of week:
Press and hold in the "MODE" button until the display starts flashing. (This is the alarm time.)
Press the "MODE" button again; the seconds begin flashing. Press "ADJ" to set them to zero.
Press the ""ST/STP" button to change what you want to set. The
options appear in this order each time you press the "ST/STP" button:
minutes, hour, month, day, day of week.
Use the "ADJ" button to change the value of the setting.
Touch "MODE" to save the settings and return to time mode.
The website listed below has many instruction sheets, but does NOT have instructions for this watch as of 25 December 2008.
Check:
http://www.armitron.com/WatchInstructions.html
SOURCE: need manual for armitron sports watch 40/8172
Go to the Amitron web site , "amitron.com".
Select "support" and the "watch instructions" from the drop down menu.
There will be a number of illustrations
Using the arrow heads on the right, scroll down to the bottom and select the one marked "mens digital".
This file contains the instructions for two manuals, the one you want is the second one (scroll down to reach the 40/8 series).
Testimonial: "Thanks man,just what I needed!Great tip!"
SOURCE: Looking for instructions on a (UNLISTED watch MDL#1070)
You can get the instruction manual here:
http://www.genevawatchgroup.com/pdf/unlisted/UNLISTED-GENERAL-ANALOG-DIGITAL-INST.pdf
