Garden Logo
J
Joe coney Posted on Nov 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to release Stuck exhaust valve 3hp b&s upright motor
seanyboy
Level 2:
Habit-Forming:
Scholar:
  • Expert 111 Answers
  • Posted on Jan 25, 2020
seanyboy
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
111
Questions
5
Helped
54224
Points
170
You can do it the correct way and take off the head, gently tap saw sa the valve down, release the tension spring annd keeper (through the access port of course) making sure to stuff some into the oil journal draining g no i to d use a small spring compressor and squeeze the spring to it’s max comp, tear a piece of emory cloth into 1/4” or so. Not too wide. Stuff a pssaper towel, oiled is best, and block off the other port and journal and wrap that emory cloth around the exhaust valve where the galding occurred. Saw the cloth around the valve back and forth, twisting the valve 1/4 turn every 3 or 4 strokes. Just enough to take the purple/brown haze down a little. I use WD-40 after each pass to keep it as clean as i can and and lAfter you use the emorydThat’ll get your valve out. Reverse process, sither using engine assy lube (what i use) or jusr coat the well.... you know. Lol. Check to make sure your oiler journal from the crank case -to-valve oil junction is freed and clear to receive clean fresh oil.
Izuku Midorya
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 11, 2019
Izuku Midorya
Contributor
Level 1:
Answers
Questions
0
Helped
160
Points
5
1helpful
2answers
Why does my 14 1/2 hp briggs and stratton riding mower muffler glow red after 2 min running..runs ok..just glowing red muffler.
Possible bad exhaust valve would allow burning fuel to enter muffler.
If you could do a compression test it would indicate that one cylinder is low.
Mar 11, 2016 • Garden
Why is their no compression in one cylinder in my 80 ci evo motor
1) ETHER THE INTAKE VALVE OR EXHAUST VALVE IS STUCK. CHECK FOR FREE PLAY....
2) CHECK FOR VALVE CLEARANCE SETTING..
3) CHECK FOR CRACKED ON ORROFACE OF INTAKE AND EXHAUST VALVE....
4) CHECK FOR A FORIEGN MATERIALS OR CARBON DEPOSIT ON THE IN AND EX VALVE ORROFACE....
Aug 24, 2014 • Motorcycles
2answers
Motor servo stuck r1
Your after market exhaust should have instructions about what to do with the exhaust valve. I would suggest that you contact the exhaust manufacturer and ask for their advise. They will have dealt with this on a regular basis.
1helpful
2answers
Having a problem with my p0742 will I need a new transmission?
How would some know that?
I assume you haven't even had it road tested yet
by a trans or repair shop
There are no new transmissions,only new when the
car is assembled
1helpful
Po742
Trouble Code: P0742 This should be looked at by a trusted transmission shop in your area to address this problem. This sometimes does require the replacement of the torque converter itself.
Torque Converter Clutch Circuit Stuck On (4T65-E)
Possible Causes:
TCC PWM solenoid valve for the fluid exhaust is restricted TCC regulated apply valve is stuck in the TCC apply position TCC control valve is stuck in the TCC apply position TCC feed limit valve is stuck (i.e., the TCC feed limit pressure, and the TCC release pressure to be low or nonexistent) Pressure regulator valve is stuck TCC fluid circuits leaking or abnormally low/high line pressure TCC release switch circuit is shorted to ground TSB 00-07-30-007A contains a repair procedure for this code
My mtd 3hp motor will only start when its choked but wont stay running
Check oil. are the fumes coming out of the exhaust a different color. If they are blue or black, you have an engine problem that needs looked at by a pro.
Aug 23, 2009 • Garden
2answers
Chranks hard,won't start
you need to adjust the valves with the cylinder 1/4 inch below top dead center to get the decompression lobe to function right during cranking.
Aug 07, 2009 • Garden
I'm loosing air on my 3hp air compressor, as soon as i pull that trigger on my compressor for about 2 second it looses air. No holes in the air hose nothing is wrong but just loosing air
Are you talking about the power switch or the trigger of an air tool?
If it is the power switch then how much air are you losing?
At start up most air compressors will lose a small amount of air through the unloader valve. As the compressor builds psi this valve will close. Once the max psi is reached the motor will shut off then a few seconds later the unloader valve will open again releasing the pressure in the cylinder. If your leak does not abate as psi builds you might need to replace your switch and valve.
Trips breaker starting under load
The problem that you describe is caused by pressure in the airline due to faulty in-tank check valve and/ or the unloader at the pressure switch. When the compressor cycles off the pressure switch releases the air that remains in the air line thru a small valve. There is a 1/4 " tube extending from the check valve to the switch. Listen for the release of air as soon as the compressor stops. There is a small metal tab that pushes on the unloader valve that may need to be adjusted. The motor does not have enough power to start pumping if there is air/backpressure in the air line. If these parts are working correctly then check the value of the start capacitor and use meter to measure. The cap should test within 95 % of stated value. Replace parts as needed. Enjoy
Top Briggs & Stratton Garden Experts
Jay Finke
Jay Finke
john h
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
