Heavy Machinery Logo
M
MELISSA LINN WASHBURN Posted on Nov 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I NEED A SERVICE MANUAL FOR A 1990 FRANKLIN GRAPPLE SKIDDER, FOR THE HYDROLIC SYSTEMS,SEARCH SAYS IT HAS ONE BUT THEN JUST TAKES ME IN CIRCLES?
Richard Marshall
Level 2:
Habit-Forming:
  • Expert 41 Answers
  • Posted on Nov 10, 2019
Richard Marshall
Expert
Level 2:
Habit-Forming:
Answers
41
Questions
0
Helped
23241
Points
120
Here is a company in Virginia that may be able to steer you in the right direction
http://forestryconstruction.com/content/manufacturers
4 Related Answers
Terry Corrow
johnny rebel
  • 10875 Answers
  • Posted on Mar 26, 2015
SOURCE: I don't know the year of my Franklin skidder and can't find the SN
Serial Number Guide User Guide Introduction
lpfaff1
L Pfaff
  • 11573 Answers
  • Posted on Jan 20, 2016
SOURCE: where to download service manual for John deere 648g3 skidder
press the helpful button and go to link below.
http://manuals.deere.com/omview/OMT183331_19/OMT183331_19.htm
Bud Hayes
  • 262 Answers
  • Posted on Jan 06, 2017
SOURCE: I have a 648e John Deere Skidder that labors when idling until you pull blade levers or grapple/ arch functions. What can I do to fix it?
One of the spool valves is not centered a keeping pump on high pressure. Has any of the control valves been worked on and the spools swapped in the valves. The spools look very similar but will only work in the body they come out of. That is what I have run into in the past with different model control valves. When you activate a valve lever to do a function it relives the hydraulic pump to let oil flow that is why it sounds ok when using. In the neutral position the oil has a restricted flow. Check it out to find which valve is at fault.
Bill Boyd
  • 53816 Answers
  • Posted on Jul 09, 2018
SOURCE: 648E john deere skidder grapple discharging all the time cant find problem..or its not charging ??could it be something in the wiring ?
at this point have an auto electrician check out the charging circuit
check the drive belt for the alternator
I suspect that as the unit operates in extreme conditions , the brushes running on the alternator slip rings are not making contact ( stuck up from dust) or the rectifier pack is not working and allowing ac current to the battery
next problem are is that voltage regulator that is not allowing enough voltage to the battery
checking for broken wires and corroded connections may reveal a problem area
Testimonial: "thank you"
2answers
Franklen log skidder Q90 shows er20 in display
The error code "ER20" on a Franklin Log Skidder Q90 likely indicates an issue with the transmission. The exact meaning of this error code may vary depending on the specific skidder model and manufacturer, but it typically indicates a problem with the transmission control system or a sensor within the transmission.
If the transmission will not take gear, this is a clear indication that there is a problem that needs to be addressed. The issue could be with the transmission control system, the transmission itself, or even with the engine.
If you're experiencing this issue, it's recommended to have the skidder inspected by a qualified mechanic or dealership as soon as possible. They will be able to diagnose the problem, determine the cause of the error code, and repair the transmission to ensure it is functioning properly.
If the problem is not addressed, it may cause further damage to the transmission and result in more expensive repairs. Additionally, operating a skidder with a transmission issue can also pose a safety risk to the operator and anyone nearby.
I think so too, it could be wiring, or the load.. try fluctuating that too see the affect..
get a guide also for help
even I keep getting those for free so I know a lot of websites and which one is best for what type of vehicle.
I need a wiring diagram for a John Deere 440C diesel skidder
https://images.search.yahoo.com/yhs/search?p=John+Deere+440C+diesel+skidder+wireing+diagram&hspart=att&hsimp=yhs-att_001
Top Heavy Machinery Experts
Dmitry Isayev
Dmitry Isayev
ADMIN Andrew
ADMIN Andrew
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
