If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent..
SOURCE: Original xbox
16 - dashboard - Clock cannot be set.
Basically it comes down to this. Error 16 has to do with not
finding the menu setting with which you can set the clock of the hdd.
This happens to a lot of people that erase their hdd
(original/upgraded) or MS dashboard files and after that they don't
immediatly install the hdd but leave the xbox without power longer than
5 hours.
It's all about the hdd can't find the menu with which it can set
the clock. This is mostly because the xbox hdd is empty (you removed
dashboard or fux0red it via ftp). The problem arises when xbox searches
for menu to set clock with, can't find it and voila: error 16. Well
read on please!
So you have an error 16 huh? Don't worry "nothing" is broken!
You have an xbox hdd that is locked. And normally you can boot in
original and modded mode. Retail or upgraded doesn't matter. You start
playing around with xboxdash.xbe etc. using ftp programs. While doing
this you "accidently" remove your MS dashboard and also your alternate
dashboard (Evox, etc.) so there is no dash anymore on the xbox hdd.
You end the ftp session and after that you shut off your xbox.
Normally when you would start up again it gives you an error 13/14 ( no
dashboard found). No worries with a slayer Evox cd (and a hardmod), all
is ok. BUT this is only WITHIN 3 hours or so.
This is because the internal clock of the xbox will only be kept
alive by the capacitors for only 3 or 4 hours. So when you leave your
xbox unplugged from electricity for over 5 hours after you have played
with the .xbe's AND you have removed your (ms and evo-x) dash from your
xbox than you are fux0red. Why do you ask?
Why can't I boot from disc?
Its as follows Xbox starts booting==> (almost 1st thing a xbox
does is) searches for internal clock==> doesnt find internal clock
because there hasn't been any electricity on the xbox for 5 hours so
battery that kept clock alive is empty and clock is gone==> searches
for the proper dashboard menu to set clock with ==> doesnt find
msdashboard or evo-x dashboard menu becuz you have removed it from the
hdd for whatever reasons you had==> xbox gives error 16: cannot set
clock.
So what do you do about it? Two options!
1. There are some bios'es around that allow the chip to boot past
the clocksetting. (do a search!). So how do you get that bios on your
chip because you cant boot to a flash program or something? Well you
need to have an external flasher.
It seems the m8 bios will take care for you of booting past the clocksetting. Or use the latest Xecutor bios
2. This is the more easy and newbie friendly strategy
-Get a friend with a modded xbox.
-Unlock his hdd with eeprom management from a slayer evo-x cd.
-Than, place his hdd in your xbox.
-Boot with your chip on.
-Now the xbox DOES find a dashboard when you boot in original mode and you can set the time in the msdashboard clock settings.
-Shut off xbox and remove your friends hdd
-PLace his hdd back in his xbox and lock it again
-Install your hdd
-(clock has been set) So boot up with slayer cd.
-Install normally whatever you wanna install
-lock hdd
If you get an error 13 after this, please read up on the error 13 explanation!
13 - kernel - Dashboard launch fail (due to missing/bad key, or anything else that would prevent it from running) and the dashboard didn't specify why it failed.
The error it gives is because of the incompatibility between the
(older) dashboard (4920) that older slayer cd installs and the new
dashboard/kernel versions found in some new xbox's and found in xbox's
that have been connected to xbox live (when you go on xbox-live, it'll
upgrade your dashboard file to i believe it is now 5659.03. This
dasboard is incompatible with the dash that (old) slayer cd installs
(for example 2.5 or lower) for you.
(In detail, in the eeprom chip there is a kernel which is incompatible with the dashboard (4920) that slayer installs.)
So what do you do to fix it? You can use the dashupdate found on
most new xbox games! Be sure to 1st unplug your ethernet cable before
you do so!!!
Besides that, just use a good installation disc and all is fine. Use a 2.6 slayer or something similar
SOURCE: 1 RED LIGHT BOTTOM LEFT CORNER
This usually means something is wrong with the graphics scaler. You'll eventually have to send your xbox in to have it fixed, and I believe it is covered under a one year warrenty.
SOURCE: apex GT2015 20 inch television
my television has a little red key on the bottom left corner of the screen and no picture. i don't know how i did this. how do i unlock it? thanks
SOURCE: Flashing red light, screen doesnt turn on
http://recycledpapyr.us/2009/03/26/blown-power-supply-on-philips-plasma/
I found this solution in an other forum , don;t now if you are experiencing the exact same problem though
SOURCE: LG plasma TV turned off, after the picture very light
I think you have a defective power board. the pop sound in coming from the board and giving you a low output voltage. do it yourself price about two hundred for parts.
View it in 'Flip
card' option, which can be selected from the drop down box menu by the
[Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each
posts, both at the right and bottom, might help you to find the availability of
spare parts. There are more than 850
posts to different brand TVs now.
Fauts and rectifications to many brands of Plasmas are described here in detail. Almost all plasma TVs will have the same fault indications, as they are of the same circuit configuration. Only appearance and models will differ.
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the left top left corner of the display window. It will make search easy. Some times, the ads attached with each posts both at the right and bottom, might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs now. Will be updated daily.
