Question about Ryobi Drills
P107 red light on green light flashing 2 batteries neither will charge ryobi 18 volt lithium charger working could both batteries go bad at same time
    Problem Solver:
  • 5 Answers
Replacement for Ryobi P107 Power Tool Battery
  • Type: Li-ion
  • Volt: 18V
  • Capacity: 6000mAh
  • Color: Black
  • Weight: 898g
  • Dimension: 135.70 x 76.00 x 107.30mm
http://www.drill-battery.net.au/buybatteries.php/ryobi_P107_power+tool+battery.html
  • Type: Li-ion
  • Volt: 18V
  • Capacity: 6000mAh
  • Color: Black
  • Weight: 898g
Posted on Nov 23, 2019
    Top Expert:
  • Ryobi Master
  • 66,189 Answers
Yes they could
Posted on Nov 10, 2019
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 111 Answers
SOURCE: ryobi 18v lithium battery won't charge
sound to me like you have a bad battery, a lot of ryobi batterys don't last like they should i have had the same problem, but my battery was less than a year old and i took it back and they give me a new one.
Posted on Mar 16, 2010
speedw752
speedw752
SOURCE: ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
Posted on Dec 12, 2012
I have 2 ryobi 18 volt one + batteries won't charge, blinks red. I have 2 chargers, same for both. 65 degrees here so not too cold.
Just a thought, lithium batteries wont charge in Ryobi's old chargers. I upgraded my batteries but not the charger until I found this out.
Feb 18, 2017 | Ryobi Drills
Just bought a Ruobi drill with 18V Lithium Batteries. Been chatging for over an hour. Still not charged. Just the bottom Green light stays on. Is this normal? How long does it take?
The Ryobi charger will flash green as it charges and then remain steady or slowly flashing green when fully charged. Flashing red means testing and if it remains steady or slowly flashing red it is defective.
Apr 11, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
Lights will not light on ryobi battery charger/cannot charge fairly new battery
Bad contact on battery use multymeter to check if voltage is there if not open the battery pack and see if bad connection exists or try another battery
Dec 25, 2017 | Ryobi Multi-Volt Battery Charger
Makita battery charger wont charge
If both lights on the charger are flashing it is indicating you have a bad battery and the charger will not charge the battery. The charger has circuitry that tests the battery and if it 'thinks' the battery is defective it will not attempt to charge it. The only way to verify whether it's the battery or charger is to try charging your battery on another charger or try charging another battery on your charger. Most of the time it's a bad battery.
Aug 02, 2012 | Makita DC18RAX230 230-Volt LXT Lithium-Ion...
RYOBI CHARGER RED AND GREEN FLASHING LIGHT
Try rotating the plug that goes into the wall. I know it sounds irrelevant but ive had the same issue and it worked for me. The positive and negative may be reversed in the dock.
Jan 04, 2012 | Ryobi Multi-Volt Battery Charger
My 18 volt Ryobi battery shows charged in charger (Green Light) But will not work in any of the power tools. I have three other Batteries that do work. Bought at Home depot on july 24 2011 Ryobi Two 18V...
Some of batteries drain very quickly. Depends on how they are used.
Feel free to check Your Local battery Manufacturer for best prices for all different batteries. You name it and they have it or they can custom make a battery for you.
Thanks
Oct 09, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
When putting the battery in the charger the red and green lights flash indicating a bad battery, cannot charge battery.
Have you tried just waiting a few minutes, it might start to charge anyway. But if not, is there some reason you would assume that you don't have a bad battery? There are lots of bad Li-Ion batteries.
Sep 03, 2010 | Makita BL1815-2 18 Volt 1.5 Ah Compact...
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
May 17, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi 18v lithium battery won't charge
Mar 15, 2010 | Ryobi 3-piece 18V Drill / Circular Saw /...
Drills Logo
Top Ryobi Drills Experts
JOHN LAPIER
roeb
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
