AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
To recall an error code,
Wake the machine by pressing any button Wait
5 seconds Press and hold the Start and Pause Cancel buttons
simultaneously Ail LEDs will go blank and after a few seconds the control will signal the
stored code using audible beeps and blinking LEDs. The control will repeatedly
signal the code, as long as the Start and Pause Cancel buttons are
pressed. A two-second pause between repeats affords you the ability to make
accurate counts to identify the correct error codes. you
may also have a code such as E47 or E24 etc.. Comme back with the code and I will explain what is the meaning of the code
not drying all the way
