SOURCE: Exesive sparks on the brushes (Bosch GSB 16RE drill)
If you used the drill any amount with a burned field coil there is a good chance that is has burned the new armature out.
SOURCE: locked drill chuck
i have the same tool and have had the same problem
i use 2 large prs of channel locks(water pump pliers) to break the bond
SOURCE: Hi, I have a dewalt dc925 drill. When running the
They all do that a bit. The sparks when starting up and stopping are normal. If it has been used alot brushes may be a good idea but before they need to be changed it will spark quite a bit.
It will not hurt to inspect the amount of brush material remaining.
Testimonial: "Thanks for your help! It looks like there is still some live left on the brushes...I guess I was just overly concerned! :)"
SOURCE: how do you replace the brushes on a Bosch Drill GSB18-2RE
The brushes are usually accessable from the outside, sometimes not, but just remove the plastic cover with a screwdriver, with it unplugged and the brush pops out, replace with one the same size.
