I have tried everything but when looking through the eyepiece it is upside down
SOURCE: everything is upside down
Astronomical telescopes produce an upside-down and reversed image (image is rotated 180 degrees from an upright position) since this doesn't matter when you are looking at things in the night sky. Accessories are available for rotating the image to an upright position, but most of those accessories do not work well with Newtonian style reflector telescopes such as the 114EQ reflector.
Yes all astronomical telescopes are upside down! No up or down in space!
You can buy an erecting diagonal for about $45 from Orion Telescopes to use for terrestrial viewing.
SOURCE: things are upside down looking thru the eyepiece on main telescop
If things are upside down in your telescope, you probably have a reflector telescope.it has curved mirror in the sealed end.take off the cover near the finder and point in the general direction of what you want to see.Make adjustments with the stuff on the mount.If you are viewing terrestrial objects, you will need an inverting lens to correct the image.It is called a Barlow lens and is much longer than the other lenses that come with the telescope.Good Luck
SOURCE: view upside down
There is nothing wrong. All astronomical telescope show object as upside down. There is no up or down in space!
SOURCE: When viewing everything is upside down.
Yes, all astronomical telescopes show images upside down. There is no up or down in space.
