Question about Frigidaire Ovens
I misplaced my manual and need to have instructions to use the self-cleaning feature.
My oven is a Frigidaire Gallery series NF20914439, Model FGEW3045KFB
  • Frigidaire Master
  • 6,073 Answers
First take out the broiler pan, insert and any aluminum foil. Remove any other tools or pans from the oven. Next clean any large deposits in the oven cavity with hot, soapy water and a cloth. Clean the oven frame, the area outside of the door gasket and the very front center of the oven bottom with soap and water. Once you are ready to start the Self-Clean cycle, press the Self-Clean touch pad. To change the length of the Self-Clean cycle, press the pad again, as needed. Press Start. If you want to have the Self-Clean delayed, press the Delay Start touch pad after the Door Loc message appears. Type in the start time with the keypad.
To stop this cycle, press Cancel. If the oven is hot, the door will remain locked.
Frigidaire has most of their manuals available on their support site: http://b2b.frigidaire.com/support/manuals.asp . The current link to the English version of the Owner's manual is http://manuals.frigidaire.com/PDFnotFoundCheck.asp?path=ftp://ftp.electrolux-na.com/ProdInfo_PDF/&folder=Lassomption&PDFtype=Owner&PDFfile=318205312en.pdf&model=FGEW3045KFB . See pages 24-25 for this information.
I hope this helps.
Posted on Nov 05, 2019
5 Suggested Answers
Donni Steen
  • 687 Answers
SOURCE: I started my oven on ''clean'' -- how long should this take?
Whithout knowing the model number in general it takes several hours for the cleaning cycle. My oven takes approx. 4 hours to complete a good cleaning. On my own oven, you can set the timer for as long as you want. Do you have an owners manual? If not, you can find one here...........
http://www.frigidaire.com/support/manuals.asp
Posted on Mar 21, 2009
ejasperse
  • 189 Answers
SOURCE: The self cleaning instructions for my Frigidaire
Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'!  Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
Posted on Mar 19, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: The self-cleaning cycle on our oven stops mid-cycle
I would never use the self clean in the first place...it causes many problems. I see many problems on Fixya everyday because of this feature...
Check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Mar 28, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: i need instructions to start
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on Sep 14, 2010
  • 6073 Answers
SOURCE: I have misplaced the manual
First remove the racks, broiler pan (complete) and any aluminum foil that is in the oven. Hand clean any large deposits inside the oven. Use a non-abrasive cleanser, not an oven cleaner. Clean around the door frame and the edge of the door (outside of the gasket) with hot water and detergent. Close the door to the oven and make sure there are no plastic utensils near the vent of the oven. Make sure that your kitchen is well ventilated.
Next move the lock lever to the right. Set the Oven Selector and Oven Temperature both to Clean. Make sure that the clock, Start and Stop times are set to the correct time. Then push in and turn the Stop time knob clockwise to 3 hours (normal cycle). Make sure the Start time knob is not pushed in. Now wait for the cleaning cycle to be completed and for the oven to cool down. The lock lever can not be moved back to the left until the oven is cool. Forcing it will break it. Turn the Oven Selector and the Oven Temperature knobs to Off.
The manual is available here: http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203189075.pdf . If the direct link doesn't work, start here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=WHRCOM and enter the model number and then click Go.
I hope this helps.
Posted on Apr 27, 2011
I have a frigidaire gallery wall oven (2003). We set the self cleaning and then canceled. The door is now locked and the fan is running. I tried to reset breaker and it is still locked. How can I get the...
If tripping and turning the circuit breaker off for about 10 minutes does not work, contact Frigidaire. Sounds like the control board and/or door switch will need replacing.
Aug 07, 2012 | Frigidaire 30 in. Electric Gallery Series...
I need the instruction manual for a frigidaire gallery oven
Here is a link to a website that says the manual is for a wall oven - http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318205312en.pdf
Here is the link to Frigidaire manuals as well and maybe you can find the manual there if the first link is incorrect -
http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/
Aug 08, 2011 | Frigidaire 30 in. Electric Gallery Series...
The inner oven glass of my self-clean oven has a small crack. Can I still use the self-clean feature?
No, that may be what cracked it in the first place...the self clean or self destruct feature will noly finish it off for you...
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 23, 2010 | Frigidaire 30 in. Electric Gallery Series...
heatman101
Mar 27, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The self cleaning instructions for my Frigidaire Gallery Pro Series Model FEB798WCCH do not inform how long to set timer. Any instructions would be helpful as I've never operated a self cleaning oven...
Mar 19, 2010 | Frigidaire 30 in. Electric Gallery Series...
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
Jul 13, 2009 | Frigidaire 30 in. Electric Gallery Series...
I don't have a manual for this diswasher.
u can go to there site or type in the model numbers and/or the model it self and after that typ manual and it should come up on the intranet
May 01, 2009 | Frigidaire 30 in. Electric Gallery Series...
Mar 20, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
57 people viewed this question
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
