Hello, i have a Xerox Phaser 6110 printer, no matter what i print i get a faint blue / red image all the way down one side of the paper, and feinter streaks across the rest of the paper, i have cleaned inide the unit & the imaging unit (although there wasnt any obvious print toner about), i have changed the toners for new and still the problem persists, it is doubtful that the printer has printed off more than 1000 sheets to date
SOURCE: Xerox phaser 7760 streaking
to fined out what the problem could be you need to open a word doc and sent a blank page to the printer. from this it will show where the problem is in the printer
if u still get streaking it couls be a faulty toner and it may not be the cyan toner either. i would give the fuser unit in the printer a check. if there marks on tthis unit i can cause this problem as well
SOURCE: phaser 7400 not printing red
I would suspect you do not have drive to the red imaging unit area. A gear may have fractured, a motor not runing, which would normally give you a fault code, or a clutch is slipping not driving the red components.
SOURCE: Xerox Phaser 6125 Color Printer
I called Xerox and it seems that it's because the imaging unit is defective. They are seeding me one free of charge. Hope you can do the same...
SOURCE: Large Toner Streak... Bad Imaging Unit?
Check to see if you waste toner recycling for the cyan is working or being blocked. Check the transfer bias roller next to the cyan drum. Return you cyan imaging unit for a warranty replacement. Check for obstructions to the cyan developing unit. Check that the cyan IU was put into the machine properly. Check for toner leaking from the entrance to the developing unit or from the toner cartridge.
or, call a qualified KonicaMinolta tech to check out and service your machine.
SOURCE: Print quality problems after installing imaging unit.
pon ese en el amarillo, si el fondo ahora es amarillo....
The blinking toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner. See "Redistributing Toner" on page 5.2
from the manual online as pdf: http://download.support.xerox.com/pub/docs/6110/userdocs/any-os/en/Guide_XP.pdf
