According to the diagrams for those, it appears to be an unloader line which means the compressor unloads after stopping via the center of the crank shaft. It would therefore be an air line.
That is made by Gardner Denver under the same model number. I could not find a manual for it but here is their site. I would contact them and see if they can furnish you one.
Hi alan, my name is John. Welcome to FixYa. try loosing the valve at the bottom of the tank and bleed all the water and stuff out until nothing comes out. Thanks for choosing FixYa....John
Is this a rotary screw compressor? If so, is it blowing oil out of the air filter or out of the discharge air lines? If it's blowing oil out of the air filter you have a oil stop valve or minimum pressure check valve bad. If oil is coming out of the discharge air you need to change the seperator.
Your looking for a rebuild kit for a low production, high end compressor pump. You have two choices. The first is to search and maybe stumble across the parts you need, I have a better chance at finding the parts and I know it will take a while. The other choice is to contact a supplier for the kit. It will be a lot quicker. Trust me.
Try the link below. Just fill out the info and if it's available they will find it. In the mean time I will try a couple other sources and if I find anything I will post it here. The second link is direct to Gardner Denver. Hope this helps.
I have a 2hp craftsman air compessor with a two cylinder pump, Here is the info from my manual as far as oil capacitity:
Remove oil fill plug and slowly add
a compressor oil until it is even with the
top of the oil fill hole. NOTE: Do not
allow oil to be lower than 3/8"
from the top at any time. When filling
the crankcase, the oil flows very slowly
into the pump. If the oil is added too
quickly, it will overflow and appear to
be full. NOTE: Crankcase oil capacity is
approximately 16 fluid ounces.
I buy my compessor oil from Lowes in the tool department. It comes in 16oz and sells for about $3. I wouldnt worry about how many ounces it holds but rather that the oil level is to top of filler hole. Lowes also sells a synthetic oil for about $7 and is recommended for severe conditions (hot / cold / used all day). Good Luck!
