SOURCE: TV shuts down
Remove the lamp assembly, There will be a screen on the top and bottom of the assy remove all dust from these screens. also check the tube at the top of of the lamp receptical this is an air cooling pathway. reassemble and fire it up. This worked for me and saved some serious coin judging from some of the other solutions I have seen (lamp and balast) ouch!!!
SOURCE: Flashlight problems
You're experiencing a switch problem, find an authorized service center in your area at www.streamlight.com or send it directly to the factory in Eagleville, PA. If you're handy they can send a switch kit with instructions on how to repair this.
SOURCE: my battery is 2 year's
Two years is actually pretty good for a rechargeable battery in regular/constant use.
Lithium-ion rechargeable batteries have around 500 recharge cycles and then will loose capacity very quickly as for your unit.
This internal Li-Ion battery will now need to be replaced.
Hope it helps.
SOURCE: the car will turn over
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave' for today.
As you evaluate my advice. solutions and suggestions, there are a few things you must keep in mind:
• A thorough diagnostic approach involves the use of technical equipment, such as voltage meters. scanning equipment and other sophisticated devices. Diagnostic tools can be borrowed from AutoZone for FREE:
• Lastly, fixing one problem can very easily reveal a problem with something that you might consider unrelated.
Subject: Engine starts and then cuts off.
Customer's exact description: the car will turn over but will not stay running. the car has not ran in
three years. when last put into storage it would run for 30 seconds and
then shut off.
Discussion: Late model vehicles are highly computer controlled to reduce emissions, maximize fuel economy and improve consumer comfort. The various control systems in vehicles are interrelated and controlled by multiple computers that constantly monitor vehicle performance through a myriad of sensors located throughout the vehicle. Based on information received, the computers adjust the vehicle performance through a series of valves, switches and motors.
If your check engine light turns on, the vehicle actually stores information on the problem.
• When you ignore a check engine light you risk:
• Further engine damage
• Poor gas mileage
• Vehicle performance problems
• Serious repair costs
A Scan Tool can be used to read and erase trouble codes, display, record and play back LIVE diagnostic data and perform other tests allowed by the vehicle maker. Scan tools that cover vehicles 1982 to present are available at your local auto supply dealer.
A Code Reader can be used to read and erase diagnostic trouble codes as well as other additional features depending on the tool. These tools work on all vehicles 1996 and newer.
A Code Scanner reads diagnostic trouble codes generated by the vehicle's system. Codes are displayed on the vehicle's dashboard and/or identified through audio prompts. These products work with 1981-1995 vehicles.
The customer doesn't indicate any diagnostic tests to date. A dealer or your local mechanic will charge $100-$200 to perform a diagnostic scan. However, AutoZone will provide a thorough scan for FREE. All of the suggestions cited below will require the use of a code scanner or a code reader.
This is how your problem is solved in my shop. Out of the box, I'd say that you have a problem with the fuel management system or one of the system sensors that is causing the on-board computer to make adjustments as best it can. However, there's a good chance that it's something simple and inexpensive like a clogged fuel filter, a bad fuel pressure regulator or water in the fuel tank. Anyone who tells you that a modern vehicle can be diagnosed without a scanner with the problems you have set forth is merely guessing. You car has a computer and memory and probably knows exactly what the problem is. That on-board computer is just waiting for you to ask, "What's wrong".
This is where you'll start.
Difficulty: Moderately Challenging (AutoZone will loan you the instrumentation FREE of charge)
Instructions:
DO NOT RUN OUT AND A NEW FUEL PUMP YET! This was only the opening act.
First a little background for your edification. You may be aware of all this but we've never done business before and all assumptions are off the table.
For an engine - make that any engine and irrespective of manufacturer - to run, you need three things to happen inside the engine, compression, fuel and ignition, without any one of these components the engine will not run.
All of the above systems are monitored by the GM Powertrain Module (a.k.a. on-board computer). A diagnostic scan retrieves any inform related to the malfunctioning parts and tells you precisely what is wrong.
Whenever your engine cranks but does not start, runs rough, staggers, sags or cuts off, follow this Troubleshooting Guide. Some of these steps require a code scanner. They are costly but remember that AutoZone will loan you one for FREE.
If you have trouble using the code scanner or interpreting the codes click on the following link and use my access code (carrepair): Free Automotive Repair information for Users of a Code Scanner
I know that the above is wordy but I wanted to do more than just tell you that your problem is complex.
All the best,
Ben
SOURCE: my 3ds won't turn on and it fully charged
You probably have a blown fuse. Here is a video showing how to fix it. If you are not confortable doing the repair send it to nintendo to fix it.
