Gary, Faulty fuel pump sending unit. Most of the forums I checked say this a big problem with Polaris, most say the pump and sending unit have to be bought as a assembly.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
for an informantion, please visit the website below. If you need more information about a specific electrical issue you can reach me at [email protected]
Sounds like you may need a valve job. Have you been keeping the valve clearances adjusted? It's important to do that on a four-stroke engine. Check your compression to find out if the valves are ok.
My 2005 700 efi is doing the same thing. So far I have found that the engine and exhaust get so hot that the fuel starts to boil and causes the fuel pump to vapor lock. I taped up the tank with some reflective tape/insulator stuff and now I'm trying to figure out why its running so hot.(The exhaust manifold glows red hot) I've cleaned the radiator and flushed the system. I just need to check the water pump and thermostat. Any other suggestions?
