Lg washer leans in the bottom somewhere. water gets on rite side where side panel is bent to attach the bottom to it looks like to me. I've the top off, if I look straight down, where the side ends, that's where the water is an it looks like it
SOURCE: front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
SOURCE: LG front load washer -- water leaks
First, clean off the bottom of the door glass where it contacts the gray tub gasket when the door closes. Any hair or other build up can result in leakage. Second, if that does not completely solve your leak, you can move the location of the spring which holds the tub gasket from the very bottom (6 O'clock position) to the hinge area (9 O'clock position). Third: Sometimes, the reason you get a leak is due to the installation. If the washer was pushed into place by applying pressure in the center front of the washer, the outer front panel can be slightly deformed (inwerd) resulting in leakage from the door. If that is the case, sometimes you can remove the outer clamp and outer part of the gray seal and pull out on the front panel to correct the situation if it is not too severe, rather than replacing the entire front panel.
SOURCE: I have water coming from the bottom. How do I take
remove the 2 bottom front panel screws-mike
SOURCE: LG wm2101hw 4.0 cu.ft front load washer is leaking
same problem. LG stated I am using too much soap. Cant be because it still does it with no soap. Also have issues with spinning on bed comforter and also drum will not drain. I can wring out a 16oz of water from a cotton shirt sitting in the bottom of drum when completed. Floor is flooded and I am **********. Bought in April 2010 and have had 4 techs out to look at it, but there is no problem. Biggest waste of 600 I ever spent.
