Perhaps contact a seller online by email to request assistance or source of a manual.
Example:
https://www.rakuten.com/shop/areatrend/product/1682165683/
Apparently also sold by JC Penney and Walmart, and might try visiting those stores, or contacting them to ask for assistance.
SOURCE: casio watch problem
Appreciate the direct "Ask Me".
Offhand, I would say yes to the battery replacement. Though watches are not within my immediate field. This would be based on your post "2-5 minutes behind". As to the "lost signal" after a reset, may I request that you post back the specific model number pls.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
SOURCE: Daylight savings time switch?
Visit www.citizenwatches.com
Choose TECHNICAL SUPPORT and solve all problems.
SOURCE: Daylight bloody savings
Follow this link:
http://world.casio.com/wat/download/en/manual/
Rate me, please.
SOURCE: daylight savings time change casio
An example for G-shock: I searched for casio g-shock manual and got this: http://world.casio.com/wat/download/en/manual/
You enter model from back of watch and it gives you a searchable PDF manual.
For mine, model 2638 (and likely most G-shocks), you press and hold the upper left (Adjust) button until the City Code flashes. You then press the lower left (Mode) to enter DST mode then press the lower right (Receive) as it cycles through On, Off and Auto.
On moves 1 hour forward, Off moves 1 hour back. After you select, you press the upper left button (Adjust) twice and it's set. I would not pick Auto anymore as my watch is still set to the original DST days which were changed in the US years ago and no longer match, I don't believe the DST days used can be changed by the user and I don't believe Auto receive adjusts for DST.
