Your problem rely on the initial settings, your voltage is too high or your wire feed speed it's too slow. Compensate both, or just decrease you voltage.
This machine is an auto adjust for different voltages.
The front end of the circuity is a PMPS or pulse mode power supply. No matter the input, the output is the same.
Most all small appliances today are built around this technology. I bet a small IC on the circuit board has gone bad. A good electronics repair man could fix this or you can get the board from Miller.
Guessing you measured the power at the solenoid and therefore you have a voltmeter.
Disconnected the solenoid wiring and measure the Ohms across the coil of the solenoid.
You should read some relatively low resistance 200, 500, 5000.
Not meg-ohms.
We have Mig Guns and spares to suit a wide range of Mig Welders. ... Torches are usually Euro Fitting and are typically fitted to professional mig welding machines of ... attitudes from people one is giving money to ! its great to get good service.
Lincoln Electricshipment must be made by the purchaser against the transportation company at the time the shipment is received. SAFETY DEPENDS ON YOU. Lincoln arc welding and cutting equipment is designed and built with ... properly fitted and with proper grade of filter plate .... Semiautomatic DC Constant Voltage (Wire) Welder.
Hi:
By the description sounds like the trigger itself is the problem, have you try to bypass (bridge) the connection (disconnect the gun's plug from the machine and use a clip to bypass it at the machine's end) and see if the problem persists?
If the problem continues, then the problem would be the heat sensor.
I always tell my customers that the best machine for a body shop is a millermatic 212 if you have 220V available if not, go to a Millermatic 211 this is one is a dual voltage unit 110V/220V. if you can afford it buy a spool gun SG100 for all aluminum parts, the machine will cost you 999.00 and the spool gun 215.00. Best investment ever for your shop.
