Question about Kohler Plumbing
Kohler one handle shower faucet fixture will not turn off
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 18 Answers
Look up the Kohler 800 number. Their parts have a lifetime warranty and they will gladly send a replacement part.
Posted on Nov 06, 2019
    Top Expert:
  • Kohler Master
  • 66,486 Answers
THEN CALL A PLUMBER TO REPLACE IT
Posted on Nov 02, 2019
Anonymous
SOURCE:
Anonymous
  • 68 Answers
SOURCE: Pressure problem with Kohler shower faucet??
Hi pglaw,
My best guess is the supply valve for the hot side isn't open all the way. This valve is right on the valve and is accessed by taking off the front cover plate. This would still allow the pressure balancing valve to let water through but then you would have a small flow on the hot side.
If this isn't it then then cartridge is bad.
Please rate this response and good Luck,, phil
Posted on Dec 31, 2008
Anonymous
  • 195 Answers
SOURCE: kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Posted on Mar 16, 2009
Anonymous
  • 11 Answers
SOURCE: faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
Posted on May 07, 2009
David Burk
  • 49 Answers
SOURCE: Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Posted on Sep 03, 2009
Bruce Hathcock
  • 3600 Answers
SOURCE: Kohler Fairfax shower faucet repair
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
Posted on Sep 27, 2009
My pfister shower cold water faucet handle broke off. The stem is stuck so I can't replace the faucet handle. How do I remove this stuck portion of the old handle?
the model is needed for a step by step but. if your faucet is for a sink and not a shower then the handles may be connected to the pour spout or separate depending on model and in either case there is a nut screwed under the fixture that hold it in place. do not unscrew any of the faucet until you have turned of the water running to it.
here are links to the different types
Price Pfister Bathroom Sink Faucet Repair
Moen 4570 Handle Fell Off But Then Fixed It Here How
How to remove kitchen faucet
and just in case it is a bathroom fixture
Maintenance How to Remove Replace Cartridge on Single Handle Tub Shower
Sep 03, 2017 | Plumbing
How do you repair a leaky centerset Kohler forte fauset
That faucet has a lifetime warranty. Call Kohler (1-800-4-Kohler) and tell them you need a new cartridge for a K-10270 faucet.
May 01, 2014 | Kohler Forte Two Handle Centerset Lavatory...
I changed out my Kohler shower diverter cartridge because it was leaking after doing so when you open any faucet in the house it will leak the more faucet you turn on the faster it leaks. The lady plumber...
did your old diverter have a shut off knob on it? if so you may have not noticed it leaking, -what causes that is the existing shower faucet may have been mounted to high from the spout below -or the pipe going down from existing fixture to the tub faucet spout pipe may not be at least 3/4", -if its 1/2" it will always do that
Sep 06, 2017 | Kohler Home
Very little cold water from shower valve
If this is a new installation and has always beenj this way, then I would suspect that there may be an obstruction in the cold water line leading to the valve. Or something stuck in the valve at the point where the cold water is connected. If someone has worked on thius valve recently , then I would suspect that they got the valve cartridge in backwards, If the catridge is not placed in the valve correctly the opperation is messed up.
May 06, 2010 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Replaced single handle shower faucet with rite
u hve to adjust the temprture ring i think u put it all the way so u lock it ,
Dec 25, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Oct 07, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Sep 27, 2009 | Kohler Fairfax Single Control Lavatory...
Kohler shower facuet pressure balancing problem?
ever since the pressure balancing regulations came out for shower valves, they have went from simple to very complicated devices. sounds as if some foreign material caused the valve to stop working. that valve is quit difficult to reassemble correctly because there is only one way it works and can be assemmbled many ways that do not work concerning alignment of the ports. if you dissassemble it and check that all the moving parts are functioning in the balancing cartridge you can then look closely at the alignment of the ports on the cartridge that the handle is connected to. understanding how the port align as the handle is turned should assist you in assembling it correctly......hope this helps.
Jan 20, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Plumbing Logo
47 people viewed this question
Top Kohler Plumbing Experts
Mike
Thomas F. Schneider
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
