Question about Welding Tools
My Millermatic 211 wont feed wire fan and air come on when hit trigger,and temp light blinks twice, problems with trigger?
2 Suggested Answers
6ya staff
SOURCE:
luis_david
David Soto
  • 414 Answers
SOURCE: millermatic 211 temp light flashes when machine is
Hi:
By the description sounds like the trigger itself is the problem, have you try to bypass (bridge) the connection (disconnect the gun's plug from the machine and use a clip to bypass it at the machine's end) and see if the problem persists?
If the problem continues, then the problem would be the heat sensor.
Posted on Aug 25, 2011
Millermatic 211 when its plugged into 110 it welds fine but when i plug it into 220 the fan kicks on like normal but i get nothing on the gun and no wire feed shop said board miller says its a relay.
This machine is an auto adjust for different voltages.
The front end of the circuity is a PMPS or pulse mode power supply. No matter the input, the output is the same.
Most all small appliances today are built around this technology. I bet a small IC on the circuit board has gone bad. A good electronics repair man could fix this or you can get the board from Miller.
Jun 20, 2018 | Miller Welding Tools
I have a millermatic 175 it is new the over temp light is on . what could be wrong. and no wire feed.
You bought this brand ne from a merchant?
Take it back.
The over heat light is when you have welded too long and it shuts down to cool off; were you welding?No wire feed is too vauge; you looked at feed motor and the wheels aren't moving?
https://www.youtube.com/watch?v=ophtUI7RbmU
Sep 12, 2016 | Welding Tools
New welder, only fed wire a couple times now it wont work
the noise you hear is the relay for the wire feed,it means that your tension on the wire needs to be set,tighten it if it is too loose and loosen it if the roller on the feed is moving but the wire is not,also,make sure the wire moves easily in the handle,always keep your cords straight so they dont bind.
May 05, 2015 | Millermatic 212 907405 Auto-Set Mig Welder...
My trigger to my millermatic 250 won't stop feeding the wire even when switch is not pressed
Does it feed with the trigger plug removed from the machine? If so, then it is a circuit board. If no, then wires shorted somewhere in the gun.
Apr 17, 2012 | Miller Welding Tools
Millermatic 211 temp light flashes when machine is turned on. fan is running and air flow is not blocked. if i unplug the little plug for the gun and plug it back in the wire will start feeding all by...
Hi:
Aug 25, 2011 | Miller Welding Tools
My 211 Millermatic welder is experiencing burnback no matter how low I set the power. Why is it and what can I do to stop it?
Your problem rely on the initial settings, your voltage is too high or your wire feed speed it's too slow. Compensate both, or just decrease you voltage.
Nov 07, 2010 | Welding Tools
Miller 130XP won't feed wire
need a replacement wire feed motor for a millermatic 130xp
Dec 28, 2009 | Miller Welding Tools
Millermatic 200 wont feed wire
sounds like a loose or bad connection, resolder the soldered joint, these do hide hidden problems. The "blue things" might be capacitors, be ever so carefull if you remove them or you will get an awfull shock, an electrician will have the equipment to test these out, play it safe,
Dec 28, 2009 | Welding Tools
Welding Tools Logo
57 people viewed this question
Top Welding Tools Experts
David Soto
David Soto
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
